Warning message
Routable VPN Between ASA and Windows RRAS
Feb 3rd, 2014
Hi all,
I'm trying to figure out the best way to create a routable VPN between my production network and a small DR server that I have colo'd offsite.
On the production side I have an ASA 5515-X (10.1.0.0/23) and on the DR side I have a Windows Server 2012 R2 server running RRAS, DHCP, NAT, and Hyper-V.  The DR server has a virtual environment with a subnet of 10.5.0.0/24 behind NAT (diagram attached for a visual).  I've seen some tutorials online for how to create a routable VPN between the two, some utilizing the Windows Advanced Firwall to create an IPSec tunnel.  So far, I've not been able to get the tunnel to come up.
Before I spend even more time trying to troubleshoot this, I was wondering what the best way to create a secure connection between these two subnets is and if anybody has done something similar successfully.
Jason
Jason Mon, 03/24/2014 - 10:55
None yet, I've been stuck on this for a while now.  My latest attempt caused the DR site to go offline and required hands-on at the colo site to get it back online due to a bad ipsec policy, so I've backed off a bit on trying things.
grandisle Thu, 10/02/2014 - 07:11
I am looking into the exact setup you are currently trying (or tried) to implement.  Did you have any luck?
Any words of wisdom and/or tips/tricks?
Thanks!
RR
Jason Thu, 10/02/2014 - 07:49
I've given up trying to make it work at this point.  I'm definitely interested in getting this to work still.  If I see any suggestions, I'm happy to guinea pig it :)
Jason
I had this problem myself right now. I didn't find any answer from Cisco's site, I'm going to post the one that I found on Microsoft site:
https://blogs.technet.microsoft.com/networking/2015/12/27/windows-server-2012-r2-vpn-interoperability-with-cisco-asa/
In the document says: "Cisco ASA being an End-Of-Line product, the OS update for these devices seem unlike". Well this information had helped me 2 weeks ago when I order the ASA firewall and choose another option.
I will try to implement the solution and tell you how it goes.
