Unity Connections 8.5 - Mailbox Access Rights
Feb 4th, 2014
Is it possible in Unity Connections 8.5 to have a mailbox setup where anyone who has the ID and PIN can access and listen to the messages but cannot delete the voicemail messages. There would be only 1-2 to users have the capability to delete the messages.  I have a request to setup an attendance dial in mailbox where it can be checked by multiple users but only a select few would have the ability to delete the messages.
Thank You
Overall Rating: 5 (4 ratings)
tonyperla Tue, 02/04/2014 - 07:00
  • Silver, 250 points or more
Assuming this would not be a SIB user, you could simply remove the option to the delete message from the keypad mapping and then create a new user template for those specific users using the new keypad mapping and assign it to them.
Tony
Please rate helpful posts!
Rob Huffman Tue, 02/04/2014 - 07:04
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Troy,
My friend Tony is most correct here (+5 ) The best you can
do is trick most of the users into thinking "delete" is not available.
These settings are only exposed when using the Custom Keymapping Tool
in CUC, so you won't see them on your default conversation. Let's say
you are using the Classic Conversation for your users. You can go to the
Custom Keymapping Tool from cucadmin and say select Custom Keymapping #3
when it comes up you would, first off, reset the mapping on all tabs to Classic Conversation
this would then replicate your existing setup. Then go to the After Message menu page and map
some key # to "message delete" I used 17 in my tests here. Then you would also uncheck the
"option is voiced in menu" checkbox so the users that you apply this keymapping to would not
be offered the delete message option.
The next step is to assign the new Custom Keymapping #3 conversation to the
required Mailbox via user>xxxx>Phone menu>Conversation>Custom Keymapping #3
and apply.
You would also set Phone menu>Conversation>Custom Keymapping #3 in the User template
area so special "restricted" mailboxes that are created can use this conversation as well
In my tests here the only thing different than this example is that we use the Optional Conversation 1
so I reset the mapping on all tabs to Optional Conversation 1 when going through the steps above.
This worked like a charm.
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
Yort Mantup Tue, 02/04/2014 - 07:09
Thank you Tony for the solution and Rob for the detailed instructions!  +5 all around.  I appreciate it.
