NAT Timeout for Failover w/ Dual ISPs
Answered Question
Feb 4th, 2014
I have failover configured, tested, and verified using IP SLA, policy-based routing, and NAT failover as outlined in this guide:
http://docwiki.cisco.com/wiki/NAT_failover_with_DUAL_ISP_on_a_router_Configuration_Example
The problem is it takes about 60 seconds for active nat translations to timeout.  Is there a recommended way to shorten this length of time other than changing the NAT timeout value globally?
Platform: 2921
IOS: 15.2(4) M4
Topology:
              ------------- ISP1 -------------
             | Int Gi0/1                      |
LAN -- WAN router                          Internet
             | Int Gi0/2                      |
              ------------- ISP2 -------------
Config:
ip sla 1
  icmp-echo 1.1.1.1 source-ip 1.1.1.2
  threshold 250
  timeout 900
  frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
  icmp-echo 2.2.2.1 source-ip 2.2.2.2
  threshold 250
  timeout 900
  frequency 3
ip sla schedule 2 life forever start-time now
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
ip access-list extended Default-Traffic-PBR
  deny   ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
  permit ip 192.168.0.0 0.0.255.255 any
ip access-list extended Media-Lab-PBR
  deny   ip 192.168.19.0 0.0.0.255 192.168.0.0 0.0.255.255
  permit ip 192.168.19.0 0.0.0.255 any
route-map Default-Traffic-PBR permit 10
  match ip address Default-Traffic-PBR
  set ip next-hop 2.2.2.1 10 track 2
  set ip next-hop 1.1.1.1 20 track 1
route-map Media-Lab-PBR permit 10
  match ip address Media-Lab-PBR
  set ip next-hop 1.1.1.1 10 track 1
  set ip next-hop 2.2.2.1 20 track 2
ip local policy route-map Default-Traffic-PBR
interface GigabitEthernet0/0.16
  ip policy route-map Default-Traffic-PBR
interface GigabitEthernet0/0.19
  ip policy route-map Media-Lab-PBR
! NAT CONFIGURATION
ip access-list extended NAT_ACL
route-map ISP1_NAT permit 10
  match ip address NAT_ACL
  match interface GigabitEthernet0/1
route-map ISP2_NAT permit 10
  match interface GigabitEthernet0/2
ip nat inside source route-map ISP1_NAT interface GigabitEthernet0/1 overload
ip nat inside source route-map ISP2_NAT interface GigabitEthernet0/2 overload
end
Correct Answer by Vishesh Verma about 3 years 6 months ago
You can use following EEM script to help in your case.
event manager applet NAT-TRACK
event syslog pattern "TRACKING-5-STATE"
action 0.1 cli command "enable"
action 0.2 wait 3
action 0.3 cli command "clear ip nat translations *"
action 0.4 syslog msg "NAT translation cleared after track state change"
Hope it helps...!!!
Overall Rating: 5 (1 ratings)
Correct Answer
Vishesh Verma Tue, 02/04/2014 - 18:15
  • Bronze, 100 points or more
action 0.2 wait 3
Hope it helps...!!!
ualbdp2c1 Tue, 02/04/2014 - 20:40
Vishesh,
Many thanks for the reply.  I think this will work for us.  Just one follow-up question...  I'm assuming it's not advised to delete the translations for the connection that is still active.  For example, that translation table has entries for both ISP 1 and ISP 2.  ISP 1 goes down, so only delete translations where ISP 1 is the inside global address.
Do you agree?
Thanks again,
Brad
Vishesh Verma Wed, 02/05/2014 - 04:53
Brad,
Yes, you can use clear ip nat inside  in the eem to suit your requirement.
-Vishesh
