Warning message
Not able to dial International Number!!
Feb 5th, 2014
Am facing issue when dialing International number...
Kindly help its really urgent.....
Feb  5 09:39:15.127: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 977
Feb  5 09:39:15.127: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x00AF callID = 0x8030 switch = primary-net5 interface = User
Feb  5 09:39:15.127: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00AF
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Calling Party Number i = 0x0081, '977'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '00913332211224'
Feb  5 09:39:15.163: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80AF
Feb  5 09:39:15.219: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80AF
        Cause i = 0x829F - Normal, unspecified
        Facility i = 0x91A10C02021DBE0606040087690107
                Protocol Profile = Remote Operations Protocol
                0xA10C02021DBE0606040087690107
                Component = Invoke component
                         3PTY Request
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Feb  5 09:39:15.219: ISDN Se0/0/0:15 **ERROR**: isdnAsn1Component: ERROR
Feb  5 09:39:15.219: ISDN Se0/0/0:15 **ERROR**: process_facility_supp_services: Decode of facility IE operation failed
Feb  5 09:39:15.219: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8030
Feb  5 09:39:15.219: ISDN Se0/0/0:15 Q931: TX -> FACILITY pd = 8  callref = 0x00AF
        Facility i = 0x91A40702021DBE800102
                0xA40702021DBE800102
                Component = Reject component
                        Invoke Id = 7614
                        Problem = General problem; Badly structured component
Feb  5 09:39:26.175: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00AF
Feb  5 09:39:26.191: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80AF
Feb  5 09:39:42.523: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80AE
        Cause i = 0x8090 - Normal call clearing
Feb  5 09:39:42.523: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x802F
Feb  5 09:39:42.659: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00AE
Feb  5 09:39:42.675: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80AE
Nishant Savalia Wed, 02/05/2014 - 02:21
  • Silver, 250 points or more
Hi Muhammad,
Please check your "calling & called party plan type" and "calling & called party number of digits" required by Telco.
Nishant Savalia
MuhammadSaad_2 Wed, 02/05/2014 - 02:25
Both are correct b/c when am dialing the number from my GSM its going.
Nishant Savalia Wed, 02/05/2014 - 02:51
The number that you are dialing from GSM is going through your gateway?
Can you please post the debug of the successful call i.e. call you are dialing from your GSM?
Nishant Savalia
MuhammadSaad_2 Wed, 02/05/2014 - 02:59
No, from My gsm am going directly towards PSTN.
Also from ISDN all national, GSM working properly only probles we are facing with International...
Nishant Savalia Wed, 02/05/2014 - 03:03
I would suggest you to provide debug output of successful through your gateway for local or national.
Also you can ask your Telco for the reason of disconnecting international call because call is being disconnected from their side. So they can provide you some information regarding their expectation for international calls.
Nishant Savalia
Manish Prasad Wed, 02/05/2014 - 03:04
When you make international call you are sending calling number as '977' to Telco , do the same 3 digit calling number you send when you dial national number from this ISDN router?
Manish
MuhammadSaad_2 Wed, 02/05/2014 - 03:05
Feb  5 10:53:51.743: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 966
Feb  5 10:53:51.743: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x00D1 callID = 0x8052 switch = primary-net5 interface = User
Feb  5 10:53:51.743: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00D1
                Standard = CCITT
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x0081, '966'
        Called Party Number i = 0x80, '98084995'
Feb  5 10:53:51.775: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80D1
Feb  5 10:53:55.887: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x80D1
        Progress Ind i = 0x8488 - In-band info or appropriate now available
Feb  5 10:53:57.475: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x00D1
Feb  5 10:53:57.555: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x80D1
Feb  5 10:53:57.555: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x00D1
Feb  5 10:54:12.499: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 918
Feb  5 10:54:12.499: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x00D2 callID = 0x8053 switch = primary-net5 interface = User
Feb  5 10:54:12.499: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00D2
                Standard = CCITT
        Calling Party Number i = 0x0081, '918'
        Called Party Number i = 0x80, '99475438'
Feb  5 10:54:12.531: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80D2
Feb  5 10:54:18.311: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x80D2
Feb  5 10:54:26.867: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x80D2
        Date/Time i = 0x0E02050E36
                Date (dd-mm-yr)   = 14-02-05
                Time (hr:mnt:sec) = 14:54:192
Feb  5 10:54:26.871: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x00D2
Manish Prasad Wed, 02/05/2014 - 03:16
Can you try by adding these commands
voice rtp send-recv
voice call convert-discpi-to-prog
Manish
Nishant Savalia Wed, 02/05/2014 - 04:08
Hi Muhammad,
Please co-ordinate online with Telco and get the feedback from them regarding call disconnect, because if you are sending correct information from your side then information from them will help you for finding the cause.
Nishant Savalia
Manish Prasad Wed, 02/05/2014 - 04:13
Hi Muhammad,
You need to check with Telco as the call was disconnecting from Telco side.
Check with them why they are disconnecting as "Cause i = 0x829F" is a Telco side error.
Rate all the helpful post.
Manish
