Warning message
EEM script to track IP and admin down port
Answered Question
Feb 5th, 2014
  • Cisco Employee,
I have a nexus 5500 switch...i need an EEM script that will track an IP address (6.0.0.5)..and if that IP is not reachable, it will admin down a port on the n5k
Thanks in advance!
Correct Answer by Joe Clarke about 3 years 6 months ago
XR does not yet support applets.  So you will need to use EEM Tcl policies.  Depending on the release of XR, you do have a track event detector.  You can take this applet to http://www.marcuscom.com/convert_applet to convert the applet to Tcl.  That Tcl policy should then be loadable into XR.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 02/05/2014 - 08:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is not possible on the N5K.  You can track an IP route or an interface, but you cannot track reachability to an IP address like you can with IPSLA on IOS.
shaunwhi Wed, 02/05/2014 - 10:16
  • Cisco Employee,
Joe
How about if i swap the 5Ks with nexus 4500X switches??
Joe Clarke Wed, 02/05/2014 - 10:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I don't believe any Nexus switch can do this.  Catalyst, yes, but not Nexus.
shaunwhi Wed, 02/05/2014 - 10:31
  • Cisco Employee,
Sorry typo from my ipad....i meant swap n5k for Catalyst 4500-X...that should be able to do it right? What would my script look like?
Joe Clarke Wed, 02/05/2014 - 10:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
On a Cat4K, you can create an IPSLA collector to ping your host, then use tracking to watch it:
event manager applet track-ping
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "int gi1/1"
action 4.0 cli command "shut"
action 5.0 cli command "end"
shaunwhi Thu, 02/06/2014 - 08:15
  • Cisco Employee,
Thanks joe! Last question...if i were to do this on XR (ASR9k) how can i do this...i have the IPSLA setup...but dont see how i trigger off of it to run CLI commands...i dont even see how i run CLI commands
Correct Answer
Joe Clarke Thu, 02/06/2014 - 10:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
