02-05-2014 02:35 AM - edited 03-19-2019 07:51 AM
Hi guys,
Need a bit of help....
We have CUPS on version 9.1.1.30000-3, I have installed 9.1.1.31900-1 on both servers…
I have switched versions ok in the Publisher, but it fails on the subscriber….
9.1.2.11900-12 is the version of the CUCM Cluster !!!
The Subscriber shows:
ACTIVE master version – 9.1.1.30000-3
INACTIVE master version – 9.1.1.31900-1
The Publisher shows:
INACTIVE master version – 9.1.1.30000-3
When switching version on the subscriber we get - “ERROR: Version mismatch. Primary host Publisher is running version 9.1.2.11900-12. Please switch versions on the Publisher and try again”
The version that error message is referring to is not the active or inactive version on either the Pub or Sub… it is in fact our call manager version!?! I am unsure why it is looking at and pulling that version number from Call manager!?!
Anyone had this before?
Solved! Go to Solution.
11-22-2015 07:35 AM
You might be hitting below defect:
https://tools.cisco.com/bugsearch/bug/CSCum92892/?reffering_site=dumpcr
Contact TAC so that they can collect install/upgrade logs and confirm the defect and then can apply the required workaround.
Deepak
- Rate Helpful Posts -
11-22-2015 10:59 AM
Hi all,
Thank you for your suggestion, this is exactly what I did. Cisco TAC applied the workaround successfully.
Best regards,
Ionescu Alexandru
02-15-2014 04:14 PM
Where you able to fix this??? I'm having the same issue.
11-22-2015 05:12 AM
I have the same problem. Any fixes found?
11-22-2015 06:43 AM
Can you run the below command from CLI of both IM&P publisher and subscriber and paste it here:
file view install system-history.log
Deepak
11-22-2015 06:54 AM
The version listed in the error belongs to the CUCM publisher
From the CUP publisher:
11/22/2015 13:07:26 | root: Restart 9.1.1.61900-7 Start
11/22/2015 13:07:26 | root: Restart 9.1.1.31900-1 Start
11/22/2015 13:20:27 | root: Boot 9.1.1.61900-7 Start
From CUP subscriber (the one with this error, 3 other CUP subscribers didn't had this error)
11/22/2015 10:06:46 | root: Upgrade 9.1.1.61900-7 Start
11/22/2015 10:47:37 | root: Upgrade 9.1.1.61900-7 Success
end of the file reached
11-22-2015 07:35 AM
Deepak
11-22-2015 10:59 AM
Hi all,
Best regards,
Ionescu Alexandru
11-22-2015 08:18 PM
That is great Ionescu. Please remember to mark the thread as answered so that it can stay on top and help others with the same issue.
Deepak
11-22-2015 10:19 PM
Can I mark the thread as answered if I didn't started it? If yes, how can I do this?
Ionescu Alexandru
11-22-2015 10:53 PM
Ah well, I did not notice that you began this thread. Maybe you cannot in that case, anyways thanks for updating the forum that the issue had been resolved.
Deepak
11-22-2015 07:42 AM
Hi there,
It sounds like it may be this bug;
Cheers!
Rob
