Warning message
3650 Version 03.03.01SE - Stack Renumbering issue
Answered Question
Feb 5th, 2014
I need to change the switch number of a 3650 stack but the IOS command
switch current-stack-member-number renumber new-stack-member-number
is not available and I'm with the lattest IOS XE version.
So what are my alternative to move switch 2 to switch 1 and to move switch 3 to switch 2 ?
Best regards and thanks in advance.
Olivier
SWITCH#
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.01SE RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 05-Dec-13 10:15 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
SWITCH uptime is 16 hours, 40 minutes
Uptime for this control processor is 16 hours, 43 minutes
System returned to ROM by reload
System image file is "flash:packages.conf"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3650-48PS (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FDO1745Q0EK
17 Virtual Ethernet interfaces
104 Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
250456K bytes of Crash Files at crashinfo-3:.
1609272K bytes of Flash at flash:.
1609272K bytes of Flash at flash-3:.
0K bytes of Dummy USB Flash at usbflash0-3:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of  at webui:.
Base Ethernet MAC Address          : 24:e9:b3:78:aa:00
Motherboard Assembly Number        : 73-15131-05
Motherboard Serial Number          : FDO17450KAS
Model Revision Number              : A0
Motherboard Revision Number        : A0
Model Number                       : WS-C3650-48PS
System Serial Number               : FDO1745Q0EK
Switch Ports Model              SW Version        SW Image              Mode
*    2 52    WS-C3650-48PS      03.03.01SE        cat3k_caa-universalk9 INSTALL
     3 52    WS-C3650-48PS      03.03.01SE        cat3k_caa-universalk9 INSTALL
Switch 03
Switch uptime                      : 16 hours, 43 minutes
Base Ethernet MAC Address          : 24:e9:b3:78:a8:80
Motherboard Serial Number          : FDO17450KAF
System Serial Number               : FDO1745Q0DZ
Configuration register is 0x102
SWITCH#
Correct Answer by aukhadiev about 3 years 6 months ago
updated#2
There are mistakes or misprints on this document
tack Manager and High Availability Configuration Guide, Cisco IOS XE Release 3SE (Catalyst 3650 Switches):
http://www.cisco.com/en/US/docs/switches/lan/catalyst3650/software/release/3se/ha_stack_manager/configuration_guide/b_hastck_3se_3650_cg_chapter_010.html#task_1110719
Via this document the comand switch current-stack-member-number renumber new-stack-member-number is global configuration mode command...
But in practice it`s, like on 3850 platform, is EXEC commnad...
So, please someone from the vendor representatives, can you contact with documentation team and and let them know about this issue?
updated:
I'm sorry, was wrong, confused with 3850...
just looked at Stack Manager and High Availability Configuration Guide, Cisco IOS XE Release 3SE (Catalyst 3650 Switches):
really switch current-stack-member-number renumber new-stack-member-number is global configuration mode command...
But in 3850 it is EXEC command...
sorry for the stupid question, are you sure that you have typed this command via EXEC mode, not via global configuration mode?
switch current-stack-member-number renumber new-stack-member-number is EXEC command...
Overall Rating: 5 (1 ratings)
ogor Thu, 02/06/2014 - 01:59
It's not so stupid and looks like the 3650 are working like 3850.
With other platform like 3750, 3750-E and 3750-X the config was enterred in global config and now it must be enterred in EXEC mode.
Thanks for the feedback
3750 config guide
Command
Purpose
Step 1
configure terminal
Enter global configuration mode.
Step 2
Specify the current member number and the new member number for the member. The range is 1 to 9.
You can display the current member number by using the show switch user EXEC command.
Step 3
end
Return to privileged EXEC mode.
Step 4
reload slot stack-member-number
Reset the stack member.
Step 5
show switch
Verify the stack member number.
Step 6
copy running-config startup-config
Save your entries in the configuration file.
aukhadiev Thu, 02/06/2014 - 02:19
  • Bronze, 100 points or more
Sorry for persistence, but you can really confirm that, in practice, this command on 3650, like 3850 platform, is EXEC command?
This is important because in document Stack Manager and High Availability Configuration Guide, Cisco IOS XE Release 3SE (Catalyst 3650 Switches):
this command typed as global configuration mode command... So there are mistakes or misprints on this document!
ogor Thu, 02/06/2014 - 02:20
Yes I confirm that on the 3650 it's in EXEC mode to enter switch command renumber. So the doc is wrong.
Olivier
aukhadiev Thu, 02/06/2014 - 02:26
Thank you, Ogor... So, please someone from the vendor representatives, can you contact with documentation team and and let them know about this issue?
Correct Answer
aukhadiev Thu, 02/06/2014 - 01:36
updated#2
updated:
Related Content
