New Wireless clients certificate not verified
Answered Question
Feb 6th, 2014
Whenever a new clients login using SSID Green,using cisco WLC 4404, there is a prompt saying certificate is not valid. No doubt, clients can connect once they accept the certificate. Is there anyway I can remove this prompt? We have ACS doing authentication.The certificate is signed by authorized bodies? Please advice
Correct Answer by George Stefanick about 3 years 6 months ago
I have indeed.
Pushing the profile can happen a few ways. If you use ISE you can push a profile in auto enrollment. Whereby you create the wireless profile (SSID, Security, Add Cert). This is delivered to the user automatically during enrollment.
Another way to make profiles and manually push is with the Apple Configurator.
https://itunes.apple.com/us/app/apple-configurator/id434433123?mt=12
You can also use a tool like Jamf for MACs to make and push profiles.
Hope this helps ..
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
"Im like bacon, I make your wireless better"
I spoke to my apple se about this very subject. The apple key chain that holds the certs isn't used for wifi. In fact apple requires a user to validate cert the first time, trusted CA or not. The cert, once trusted, is stored in the wireless profile. Blow away the profile, you blow away that WLAN cert and you have to trust it again.
Only way around the pop up, push a WLAN profile to the device with the cert ..
Correct Answer by Scott Fella about 3 years 6 months ago
You can look at the trusted ca for the device
http://support.apple.com/kb/ht5012
Get a certificate from one of the vendors who's apple has the root ca in the trust list and install that on your ACS for 802.1x or if for guest WebAuth install it in the WLC.
Correct Answer by Sandeep Choudhary about 3 years 6 months ago
Is it happening with all client or only with Apple devices ??
Also chekc this:  Configure your clients to not check the trust path of your RADIUS  server's certificate (i.e., uncheck the box that says "validate server  certificates").
Reagrds
Overall Rating: 5 (4 ratings)
rakeshvelagala Thu, 02/06/2014 - 00:48
Do we need to import this cert to ACS or anything setting to be changed in WLC? Please advice
Correct Answer
Sandeep Choudhary Thu, 02/06/2014 - 00:57
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Reagrds
rakeshvelagala Thu, 02/06/2014 - 01:05
Hi Sandeep,
Only with Apple devices. But our management do not want to have this prompt at all. Any advice?
Scott Fella Thu, 02/06/2014 - 01:17
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 Wireless
This is typical of Apple iPads and iPhones. Here is a good article in explaining how to install your root ca certificate on an iPad or iPhone. Don't worry that this isn't for wireless, because the process is the same.
http://longwhiteclouds.com/2013/01/03/installing-corporate-ca-certificat...
rakeshvelagala Thu, 02/06/2014 - 01:21
Hi Scott,
Thanks for the reply. But is there any other way where this prompt will not even be seen on the apple devices? Any changes if we can do on ACS or WLC? Please advice.
Correct Answer
Scott Fella Thu, 02/06/2014 - 01:28
  • Hall of Fame,
    2017 Wireless
Correct Answer
George Stefanick Thu, 02/06/2014 - 05:29
  • Community Spotlight Award,
    Best Publication, October 2015
rakeshvelagala Thu, 02/06/2014 - 07:47
Hi George Stefanick,
Thanks for your feedback. Just to check have you tried "push a WLAN profile to the device with the cert " and able to authenticate successfully without the pop up?
If yes, can you please kindly share the doc on how to push a profile to device?.
Thanks for your great help.
rakeshvelagala Thu, 02/06/2014 - 07:53
I am waiting for the Doc from your side for pushing the profile to the device.
For completeness and proof for other future readers, I am sharing  apple technicle white paper link below.
http://training.apple.com/pdf/WP_8021X_Authentication.pdf
"In 802.1X authentication environments, it’s important to understand the
role certificates play in the trust chain. Client devices should be able to
verify server-side certificates, and those certificates must be trusted for EAP.
This trust is established by the user. The first time the user joins a device to
an 802.1X-protected network, the device will prompt the user to trust the
server’s certificate"
George Stefanick Thu, 02/06/2014 - 07:54
Yup, good reference ..
George Stefanick Thu, 02/06/2014 - 07:55
I notice wndows 8 is doing the same as well.
Correct Answer
I have indeed.
Hope this helps ..
rakeshvelagala Thu, 02/06/2014 - 08:05
Thanks for your reply it answers almost all my questions. Is it possible to do the same on ACS?
George Stefanick Thu, 02/06/2014 - 08:28
Sorry, not sure I follow. What do you mean do the same on ACS? Push profiles? No .. You need ISE or another application.
rakeshvelagala Thu, 02/06/2014 - 08:45
Thanks! that is my question. Thanks for all your answers. You saved me a lot of trouble.
