02-06-2014 01:29 AM - edited 03-07-2019 06:02 PM
Hello everyone,
i would appreciate it if any one could help me with the following
WAN network--- switch stack---- lan ( another switch stack - access switch- end devices)
i want to configure the core switch stack as a default gateway and dhcp helper for every vlan in the lan
can anyone provide a configuration template ?
Solved! Go to Solution.
02-10-2014 07:52 AM
You would have a management address on all of your switches, but that would be for a certain vlan. You don't need to create 10 svis on the access switches if you have 10 svis on the core. Whatever your management vlan is, let's say vlan 5, would also be on the access switch. If you have vlan 5 svi addressed at 192.168.5.1 on the core, access switches 2, 3, and 4, could also have vlan 5 svi addressed at 192.168.5.2, 192.168.5.3, and 192.168.5.4 respectively.
HTH,
John
*** Please rate all useful posts ***
02-11-2014 07:18 PM
Asus,
IP Routing enables routing on the switch. It only does you good if you plan on having this switch act as a L3 device. If you're going to configure it strictly as L2 (access switches), you can leave "no ip routing" and "ip default-gateway". IP default-gateway is used when routing is disabled. If routing was enabled with "ip routing", your default-gateway is no longer used, and you'd have to configure a static route of 0.0.0.0 0.0.0.0
For example, if you have vlan 10 on a L3 switch:
int vlan 10
ip address 192.168.10.1
And you have a L2 access switch with the following config:
no ip routing
int vlan 10
ip address 192.168.10.254
ip default-gateway 192.168.10.1
This would mean that if you're in another subnet, you could get to the swich on 192.168.10.254 because it knows to send its default traffic back to the L3 switch. I must also say that you won't have the "ip routing" on L2 switches usually, but there are some exceptions on some of the newer switches.
HTH,
John
02-06-2014 04:41 AM
What kind of switch is your 'core'?
HTH,
John
02-06-2014 02:53 PM
thw core stack is 2x 3750
02-06-2014 03:00 PM
Okay, suppose you have two vlans - 10 and 20. Your dhcp server is on vlan 10. You would configure it like this:
int vlan 10
ip address 192.168.10.1 255.255.255.0
int vlan 20
ip address 192.168.20.1 255.255.255.0
ip helper-address 192.168.10.50
The 192.168.10.50 address is the address of your dhcp server. You don't need a helper address on vlan 10 because that vlan will see the dhcp broadcasts.
You can then add your others as desired:
int vlan 30
ip address 192.168.30.1 255.255.255.0
...so on...
On the dhcp server, you'll have scopes that reference these subnets. A scope for 192.168.10.0/24, 192.168.20.0/24, etc., is required. The users will get an address from the appropriate scope. The default gateway would be the address of the vlan that they're on. For example, if you have users in the 192.168.30.0/24 subnet, their default gateway is 192.168.30.1 (the address of the svi).
HTH,
John
02-06-2014 03:33 PM
could you confirm the following please ?
for the each vlan i need to configure the ip helper address under the interface vlan
for the default gateway, each vlan will use the corresponding svi address... do i need to configure anything beside the SVIs to complete the default gateway configuration for the whole box ?
02-06-2014 03:58 PM
Default gateway for the whole box? Meaning the default gateway for the switch? If that's the case, you would create a default route:
ip route 0.0.0.0 0.0.0.0
As far as your vlan, and my previous response, you only need the helper address on the svis that do not have the dhcp server on it. If your dhcp server is in vlan 1, you do not need a helper address on vlan 1's svi.
The SVIs do the routing between vlans for you. Your hosts will use their respective vlan's svi as their default gateway ip address.
HTH,
John
02-07-2014 02:40 PM
John,
thank you for your support and helpful answers.
one last clarfication, the interface facing the wan on the stack is ospf enabled. in this case i don't need the default route mentioned in the above post right ?
02-07-2014 05:08 PM
You only need the default route for routes that you may not know about. If your switch should have knowledge of all routes, a default route wouldn't be necessary. Usually the default route points toward the firewall or router that leads to the internet.
02-09-2014 04:43 AM
Thanks for the clarification.
i have another question about the same setup
i have 25 vlans ( 1 for management and 1 for WLAN management )
in terms of vlan configuration, do i need to configure a SVI for each vlan on each layer ( core stack, aggregation stack and the access switches) ? or on just the core stack ? if yes, what do i need to configure on the aggregation stack and the access switches
02-09-2014 08:14 AM
No, you'll just need to configure it on the device that is routing for the vlan. All other devices will need to be a member of the vlan and the vlan needs to be trunked up to the L3 device that has the svi on it. So, to answer your question, the vlan svi needs to be on the core stack only.
HTH,
John
02-09-2014 11:02 PM
is it recommended to configure svi for the MGT and WLAN MGT on the AGG and Acess switches ? or not SVI at all ?
02-10-2014 07:52 AM
HTH,
John
02-11-2014 10:30 AM
ok what about the no ip routing and ip default gateway commands
on the core i have ip routing and the interface facing the wan is ospf enables.
on the aggr and access i have no ip routing and ip default gateway command to the ip address of the MGT VLan ( which is also configured as int vlan MGT on both aggr and access )
is this correct ?
02-11-2014 07:18 PM
Asus,
int vlan 10
no ip routing
int vlan 10
HTH,
John
02-12-2014 02:57 PM
if i understand correctly, please confirm that the following is not a problem
- on the core stack connected to the wan, i will enable ip routing and enable ospf on the wan interface. also configure int vlan
- on the agg/access switches, i will disable ip routing and configure default gateway pointing to the ip address of the int vlan configured on the core stack
