Warning message
Required help on ASA basic setup and configuration
Answered Question
Feb 7th, 2014
I am very very new to Security/Firewall domain, As I have gone through lot of documents and understood there must be one outside interface and atleast one or multiple inside interfaces depends on the requirement.  I have attached a high level design, it shows how ASAs tobe connected to Aggre/Dist. Switches and how DMZ are conneccted to ASA via L2 Switches.  Could any one help me on this how to configure and what are basic configuration required to eastablish the network and it works. I need two inside networks one is for dmz servers and another one is other servers to be advertise to outside DC.
Correct Answer by Marius Gunnerud about 3 years 6 months ago
Is this what you are looking for?
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/DC_3_0/dc_sec_design.html
Please remember to rate and select a correct answer
Overall Rating: 5 (1 ratings)
Goutam Biswas Sun, 02/09/2014 - 22:09
Hi Parosh,
Thanks for your reply,  If you have configured same topology, could you please give me configuration sample for the same setup.
Marius Gunnerud Fri, 02/07/2014 - 11:44
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Firewalling
Which ASA model are you running and version?
A very basic configuration you could setup, just remember to change the interface numbers and IP addresses to the required values:
int gig0/1
security-level 100
nameif inside
ip add 192.168.1.1 255.255.255.0
no shut
int gig0/2
security-level 0
nameif outside
ip add 8.8.8.9 255.255.255.252
no shut
route outside 0 0 8.8.8.10
object network LAN-to-outside-NAT
subnet 192.168.1.0 255.255.255.0
nat (inside,outside) dynamic interface
http server enable
http 192.168.1.0 255.255.255.0 inside
crypto key generate rsa modulus 2048
ssh 192.168.1.0 255.255.255.0 inside
username USERNAME password PASSWORD
enable password PASSWORD
As I mentioned this is a very basic config that allows only traffic from the inside to the outside and nothing more. But you will have internet access at lease.  Also keep in mind that you should change the subnets for http and ssh to a dedicated management subnet.
Please refer to this guide for configuration guide.
http://www.cisco.com/en/US/docs/security/asa/asa91/configuration/general/interface_start.html
If you need more assistance please let us know.
Goutam Biswas Sun, 02/09/2014 - 22:12
Thanks.
What I understood from your configaration.  ASA is located inline.  Is it right my understanding?  If so could you pls. give me sample config for ASAs are connected to Nk501 & 02 with high availability.
ASA model is 5584-X but not aware about software versin, it would be latest version.
Marius Gunnerud Mon, 02/10/2014 - 00:32
    2017 Firewalling
When you say NK501 that it is a typo and that it should be N5K01 (for nexus 5000 switch 1?)
So if these are  nexus switches, and I assume you are looking for active/standby configuration on the ASA for HA.  Your configuration would be something like the following if you want full redundancy.
N5K01
feature vpc
vpc domain 1
  role priority 1000
  system-priority 1
  peer-keepalive destination 169.254.111.1 source 169.254.111.2 vrf default
  auto-recovery
interface Ethernet1/19
  description ASA01
  switchport mode trunk
  channel-group 2 mode active
interface Ethernet1/21
  description ASA01
interface Ethernet1/22
  description vpc-keepalive
  no switchport
  ip address 169.254.111.1/16
  no shutdown
interface Ethernet1/23
  description vpc-peerlink
  channel-group 1
  no shutdown
interface Ethernet1/24
  channel-group 1
  no shutdown
interface port-channel1
  vpc peer-link
interface port-channel2
  description ASA
  vpc 1
N5K02
feature vpc
vpc domain 1
  role priority 65535
  system-priority 1
  peer-keepalive destination 169.254.111.2 source 169.254.111.1 vrf default
  auto-recovery
  description ASA02
  description ASA02
  no switchport
  ip address 169.254.111.2/16
  no shutdown
  channel-group 1
  no shutdown
  channel-group 1
  no shutdown
  vpc peer-link
  description ASA
  vpc 1
ASA01
interface TenGigabitEthernet0/6
description N5K01
interface TenGigabitEthernet0/7
description N5K01
interface TenGigabitEthernet0/8
description Failover
channel-group 3
interface TenGigabitEthernet0/9
channel-group 3
interface Port-channel2
description N5K01
nameif NAME
security-level 60
ip address 10.10.10.1 255.255.255.240 standby 10.10.10.2
interface Port-channel3
description Failover link
interface Port-channel3.10
description State link
vlan 10
interface Port-channel3.20
description STATE Failover Interface
vlan 20
failover
failover lan unit primary
failover lan interface Failover_Link Port-channel3.10
failover key PASSWORD
failover replication http
failover link Stateful_Failover_Link Port-channel3.20
failover interface ip Failover_Link 10.8.4.145 255.255.255.240 standby 10.8.4.146
failover interface ip Stateful_Failover_Link 10.8.4.161 255.255.255.240 standby 10.8.4.162
ASA02
description N5K01
description N5K01
channel-group 3
channel-group 3
description N5K01
nameif NAME
security-level 60
vlan 10
vlan 20
failover
Marius Gunnerud Mon, 02/10/2014 - 00:34
    2017 Firewalling
Just noticed that I forgot to include the DMZ interfaces on the ASAs.  But I am sure that you can figure that out by looking at the other interface configuration that I provided.
Goutam Biswas Mon, 02/10/2014 - 01:29
can you tell me which interface would work for outside.  As per my understanding according to your config sample.  port-channel2 is configured between ASA and nk5-1 and 2 will be used for outside and the same port channel 2 is used for inside also with security level 60.  is that mean I need to sub interface that port channel like.
port-channel2.30 is mapped with vlan 30 used for outside security level 0
port-channel2.40 is mapped with vlan 40 used for inside security level 60
port-channel2.50 is mapped with vlan 50 used for inside security level 90
and as per your configure ASA-01 is connecting to n5k-01 and ASA-02 is connecting to n5k-02 no crosss connect between ASA and nk5 (will it be good for redundancy purpose or this is design restriction)
Marius Gunnerud Mon, 02/10/2014 - 03:09
    2017 Firewalling
If you have several VLANs that need to go through the firewall then yes you need to configure the portchannel 2 as subinterface
I did not include any configuration for the inside network as I thought it would be quite self explanitory by following the example for the interfaces going towards NK501 - 2.
ASA-01 is only connected to n5k-01 and ASA-02 is only connected to n5k-02 as per your network diagram.  Yes you could cable them redundant between the n5k switches if you wanted to do that.  I was just following your diagram.
Goutam Biswas Mon, 02/10/2014 - 03:14
Thanks,  I will check and let you know if everything works fine.  Thanks again for your help.  Another help if possible.
Do you have any documents on ASA, where it shows diagram based configuration according to Data Center Design, it would help me to understand better and corelate with my setup.
I mean different design diagram and configuration deployment solution in today's Data Center.
Goutam Biswas Tue, 02/11/2014 - 01:51
I am looking for basic design and configuration, this is very high level of design and configuration, which is little bit difficult to understand to me as freshers in Security.
Marius Gunnerud Tue, 02/11/2014 - 02:49
    2017 Firewalling
Then the only other thing that might be what you want is a configuration guide. and not a design guide.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli/Nexus5000-NX-OS-ConfigurationGuide.pdf
Let me know if this is closer
