Anyconnect ASA 5520 Error : Login denied, unauthorized connection mechanism, contact your administrator.
manish arora
Level 6
Level 6
I just configured Anyconnect on my firewall and I am getting a error that has me stumped for last 2 days. I am running 8.2.5 version on my ASA 5520. I am getting the following error when I try to connect to the ASA SSL vpn from the web browser :
"Login denied, unauthorized connection mechanism, contact your administrator."
and getting following error if I try to connect to the asa from a previously installed anyconnect client :
"Anyconnect not enabled on the device"
Getting the following error with "Debug webvpn sessions" :
webvpn_create_session: 0x00036000 (54)
webvpn_destroy_session: 0x00036000 (54) -> Client type not supported
webvpn_destroy_session: SESS_Mgmt_FreeSession(0x00036000) (54)
webvpn_session_free: 0x00036000 (54)
My WebVpn configuration is correct ( mentioned below ) and I am still using the 2 trial license that comes default with the ASA.
Configuration :
asa5520# sh run webvpn
webvpn
enable Backup
enable Outside
svc image disk0:/anyconnect-macosx-i386-3.1.05152-k9.pkg 1
svc image disk0:/anyconnect-win-3.1.05152-k9.pkg 2
svc image disk0:/anyconnect-linux-64-3.1.05152-k9.pkg 3
svc image disk0:/anyconnect-linux-3.1.05152-k9.pkg 4
svc enable
tunnel-group-list enable
  auto-signon allow ip 10.10.10.201 255.255.255.255 auth-type all
  auto-signon allow ip 10.10.9.10 255.255.255.255 auth-type all
asa5520#
group-policy SSL-IT internal
group-policy SSL-IT attributes
dns-server value 10.10.9.101 10.10.9.100
vpn-tunnel-protocol svc
split-tunnel-policy tunnelspecified
split-tunnel-network-list value SSL_SPLITACL
default-domain value XXXXX.com
split-dns value XXXXXX.com XXXXXX.com
tunnel-group SSL-IT type remote-access
tunnel-group SSL-IT general-attributes
address-pool SSLVPN_IT_Pool
authentication-server-group WindowsIAS
default-group-policy SSL-IT
tunnel-group SSL-IT webvpn-attributes
nbns-server SRV01_Private master timeout 2 retry 2
group-alias XXXX-IT enable
group-url https://sslvpn.XXXXXXX.com/it enable
IF it matters , the anyconnect was working fine during testing but when we added new group policies , it started giving this error. I have also rebooted the firewall just in case but still getting the same error.
Please if anyone had seen this issue before , it would be helpful to guide me in right direction.
Thank you
Manish
manish arora
Level 6
Level 6
This is resolved, The issue was with the Windows IAS server configuration. After redoing the radius configuration in the server , anyconnect started to work properly.
Manish
Thanks for providing us with your resolution. I upvoted your post to make the solution more visible to future folks with the same issue.
What was the solution? I'm currently having the same issues at the moment.
