Warning message
H323 incomming / outgoing calls issue
Feb 9th, 2014
Hello ,
i have new setup with CUCM 9 and i have configured cisco router as h323 gatway .
i am getting fast bz tone for both incomming and outgoing calls .    so far i have done simple configuration like PRI configuration  one VOIP dailpeer and one Pots dial peer .  Calls are hitting the gateway .
i have attached the CCapi inout result .
please advice
Ayodeji Okanlawon Sun, 02/09/2014 - 07:24
  • Cisco Designated VIP,
    2017 IP Telephony
Aslam,
Is this an inbound or outbound call...
The far end is disconnecting th call with un allocated or un assigned number,, If this is an inbound call.check the css on the gateway. it needs to  have access to the partition of the extension 0223
cisco-ani=33000883
     dest=0223
Feb  9 12:43:25.540: //49/948E898A800B/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Shalid Kurunnan... Sun, 02/09/2014 - 07:33
Dear Aslam,
As he well said, the cause value 1 indicate that the un assigned number.
so please check for the extension configuration and does the CSS of gateway contains the partition of the extension.
Shalid K.C
aslam.bajwa Sun, 02/09/2014 - 08:38
Dear ,
i have checked the CSS and PT ,i guess it fine
i have atteached the new logs , its inboundcall
BECA-VG1#
BECA-VG1#termi
BECA-VG1#terminal moni
BECA-VG1#terminal monitor
BECA-VG1#
BECA-VG1#
BECA-VG1#deb
BECA-VG1#debug voi
BECA-VG1#debug voic
BECA-VG1#debug voice cc
BECA-VG1#debug voice ccapi in
BECA-VG1#debug voice ccapi ino
BECA-VG1#debug voice ccapi inout
voip ccapi inout debugging is on
BECA-VG1#
BECA-VG1#
*Feb  9 15:38:46.487: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   remove it from the queue
*Feb  9 15:39:44.443: //-1/3BA74A998012/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=39609298
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=0223
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Feb  9 15:39:44.443: //-1/3BA74A998012/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2309778C, Call Info(
   Calling Number=39609298,(Calling Name=)(TON=National, NPI=ISDN, Screening=Net
work, Presentation=Allowed),
   Called Number=0223(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFl
ag=TRUE,
   Incoming Dial-peer=3, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS
E), Call Id=-1
*Feb  9 15:39:44.443: //-1/3BA74A998012/CCAPI/ccCheckClipClir:
   In: Calling Number=39609298(TON=National, NPI=ISDN, Screening=Network, Presen
tation=Allowed)
   Out: Calling Number=39609298(TON=National, NPI=ISDN, Screening=Network, Prese
ntation=Allowed)
*Feb  9 15:39:44.443: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb  9 15:39:44.443: :cc_get_feature_vsa malloc success
*Feb  9 15:39:44.443:  cc_get_feature_vsa count is 1
*Feb  9 15:39:44.443: :FEATURE_VSA attributes are: feature_name:0,feature_time:5
90504024,feature_id:61
*Feb  9 15:39:44.443: //61/3BA74A998012/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=39609298(TON=National, NPI=ISDN, Screening=Network,
   Called Number=0223(TON=Subscriber, NPI=ISDN))
*Feb  9 15:39:44.443: //61/3BA74A998012/CCAPI/cc_process_call_setup_ind:
   Event=0x3CF41268
*Feb  9 15:39:44.443: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 0223
*Feb  9 15:39:44.443: //61/3BA74A998012/CCAPI/ccCallSetContext:
   Context=0x222677CC
*Feb  9 15:39:44.447: //61/3BA74A998012/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 61 with tag 3 to app "_ManagedAppProcess_Default"
*Feb  9 15:39:44.447: //61/3BA74A998012/CCAPI/ccCallProceeding:
*Feb  9 15:39:44.447: //61/3BA74A998012/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1, Params=0x222663AC, Progress Indication=NULL(0)
*Feb  9 15:39:44.447: //61/3BA74A998012/CCAPI/ccCheckClipClir:
tation=Allowed)
ntation=Allowed)
   Destination Pattern=...., Called Number=0223, Digit Strip=FALSE
   Calling Number=39609298(TON=National, NPI=ISDN, Screening=Network, Presentati
on=Allowed),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=3BA74A99-90D7-11E3-8012-C067AF12E098, Outgoing Dial-peer=1
*Feb  9 15:39:44.447: //61/3BA74A998012/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=39609298
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=0223
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Feb  9 15:39:44.447: //61/3BA74A998012/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x22DD9D4C, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=39609298,(Calling Name=)(TON=National, NPI=ISDN, S
creening=Network, Presentation=Allowed),
   Called Number=0223(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-pee
r=1, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl
ication Call Id=)
*Feb  9 15:39:44.447: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb  9 15:39:44.447: :cc_get_feature_vsa malloc success
*Feb  9 15:39:44.447:  cc_get_feature_vsa count is 2
*Feb  9 15:39:44.447: :FEATURE_VSA attributes are: feature_name:0,feature_time:5
90503800,feature_id:62
*Feb  9 15:39:44.447: //62/3BA74A998012/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Feb  9 15:39:44.447: //62/3BA74A998012/CCAPI/ccCallSetContext:
   Context=0x2226635C
*Feb  9 15:39:44.447: //61/3BA74A998012/CCAPI/ccSaveDialpeerTag:
*Feb  9 15:39:44.447: //62/3BA74A998012/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Feb  9 15:39:44.447: //62/3BA74A998012/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
*Feb  9 15:39:44.447: //61/3BA74A998012/CCAPI/ccSetMediaclassIp2ipTags:
*Feb  9 15:39:44.447: //62/3BA74A998012/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
*Feb  9 15:39:44.447: //61/3BA74A998012/CCAPI/ccGet_xc_nr_asp_info:
*Feb  9 15:39:44.467: //62/3BA74A998012/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
*Feb  9 15:39:44.467: //62/3BA74A998012/CCAPI/cc_api_call_proceeding:
   Interface=0x22DD9D4C, Progress Indication=NULL(0)
*Feb  9 15:39:44.471: //62/3BA74A998012/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
*Feb  9 15:39:44.471: //62/3BA74A998012/CCAPI/cc_api_call_cut_progress:
   Interface=0x22DD9D4C, Progress Indication=INBAND(8), Signal Indication=SIGNAL
RINGBACK(1),
   Cause Value=1
   Call Entry(Responsed=TRUE)
*Feb  9 15:39:44.471: //61/3BA74A998012/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Va
lue=1
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
*Feb  9 15:39:44.471: //61/3BA74A998012/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=61
*Feb  9 15:39:44.471: //61/3BA74A998012/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x3D, gcid=3BA74A99-90D711E3-8012C067-AF12E098, t
ag=0x0)
*Feb  9 15:39:44.471: //62/3BA74A998012/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x3E, gcid=3BA74A99-90D711E3-8012C067-AF12E098, t
ag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=61, Call Id2=62, Tag=0x0
*Feb  9 15:39:44.471: //61/3BA74A998012/CCAPI/cc_api_bridge_done:
   Conference Id=0xB, Source Interface=0x2309778C, Source Call Id=61,
   Destination Call Id=62, Disposition=0x0, Tag=0xFFFFFFFF
*Feb  9 15:39:44.471: //62/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Feb  9 15:39:44.471: cc_api_get_xcode_stream : 4819
*Feb  9 15:39:44.471: //62/3BA74A998012/CCAPI/cc_api_bridge_done:
   Conference Id=0xB, Source Interface=0x22DD9D4C, Source Call Id=62,
   Destination Call Id=61, Disposition=0x0, Tag=0x0
*Feb  9 15:39:44.471: //61/3BA74A998012/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0xB, Destination Call Id=62)
   Call Entry(Conference Id=0xB, Destination Call Id=61)
*Feb  9 15:39:44.471: confID:0xB; callEntry1 callID1:0x3D, type:6; callEntry2 ca
llID2:0x3E, type:1
*Feb  9 15:39:44.471: //61/3BA74A998012/CCAPI/cc_api_caps_ind:
   Destination Interface=0x22DD9D4C, Destination Call Id=62, Source Call Id=61,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Feb  9 15:39:44.471: //61/3BA74A998012/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xB, Call Id1=61, Call Id2=62
*Feb  9 15:39:44.487: //62/3BA74A998012/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2309778C, Destination Call Id=61, Source Call Id=62,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x2,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
*Feb  9 15:39:44.487: //62/3BA74A998012/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=O
N(0x2),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9259)
*Feb  9 15:39:44.487: //61/3BA74A998012/CCAPI/cc_api_caps_ack:
N(0x2),
*Feb  9 15:39:44.487: //61/3BA74A998012/CCAPI/cc_api_voice_mode_event:
   Call Id=61
   Call Entry(Context=0x222677CC)
*Feb  9 15:39:49.727: //61/3BA74A998012/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x2309778C, Call Id=61
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*Feb  9 15:39:49.727: //61/3BA74A998012/CCAPI/ccConferenceDestroy:
   Conference Id=0xB, Tag=0x0
*Feb  9 15:39:49.727: confID:0xB; callEntry1 callID1:0x3D, type:6; callEntry2 ca
llID2:0x3E, type:1
*Feb  9 15:39:49.731: //61/3BA74A998012/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=62, Disposition=0x0, Tag=0x0
*Feb  9 15:39:49.731: //62/3BA74A998012/CCAPI/cc_api_bridge_drop_done:
*Feb  9 15:39:49.731: //61/3BA74A998012/CCAPI/cc_generic_bridge_done:
*Feb  9 15:39:49.731: //62/3BA74A998012/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Feb  9 15:39:49.731: //62/3BA74A998012/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
*Feb  9 15:39:49.731: //61/3BA74A998012/CCAPI/ccCallDisconnect:
ause=16)
*Feb  9 15:39:49.731: //61/3BA74A998012/CCAPI/cc_api_get_transfer_info:
*Feb  9 15:39:49.735: //62/3BA74A998012/CCAPI/cc_api_get_transfer_info:
*Feb  9 15:39:49.735: //62/3BA74A998012/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x22DD9D4C, Tag=0x0, Call Id=62,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Feb  9 15:39:49.735: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb  9 15:39:49.735: :cc_free_feature_vsa freeing 23325F70
*Feb  9 15:39:49.735:  vsacount in free is 1
*Feb  9 15:39:49.867: //61/3BA74A998012/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2309778C, Tag=0x0, Call Id=61,
*Feb  9 15:39:49.871: //61/3BA74A998012/CCAPI/cc_api_call_disconnect_done:
*Feb  9 15:39:49.871: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb  9 15:39:49.871: :cc_free_feature_vsa freeing 23326050
*Feb  9 15:39:49.871:  vsacount in free is 0
*Feb  9 15:42:49.871: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
Ayodeji Okanlawon Sun, 02/09/2014 - 09:13
    2017 IP Telephony
Aslam,
Can you send your sh run and also send debug isdn q931.
