Warning message
ASA 5505 - ASDM v 7.1(5) - Access Rules
Answered Question
I have got an ASA 5505 set up in front of a reverse proxy for Exch 2013.  I currently hit the outside via https://mymail.mydomain.com.  That works just fine.  There is a translation from port 8443 to 443 using Object NAT.
This question relates to the associated access rules.
I have one access rule that says, Source=any, Destn=myproxy, Destn Service = tcp/https
Everything works BUT... I would have thought that the access rule should be based on requesting access to port 8443... So, it appears as though:
- packet arrives on port 8443 and is translated to port 443, destn IP 10.0.0.n
- the firewall then says, "Aha, HTTPS packet for destn IP 10.0.0.n, that's fine.  Pass friend."
Whereas what I think I "want" is
- packet arrives on port 8443 and is HTTPS and is passed by the firewall
and then the NAT runs
The lack of obvious link between the changed port and the access rule makes me uneasy.
Am I missing something and should just relax?
Correct Answer by Jouni Forss about 3 years 6 months ago
The ASA NAT/ACL changed in the jump from software level 8.2 to 8.3.
During 8.2 and before it the logic was that for a destination address the ACL was checked first and then the UN-NAT was done which essentially untraslated the IP address (and possibly the port) and forwarded the traffic to the correct host on the correct port.
During 8.3 and after it the ordering of NAT and ACL was changed as the NAT was redone. Now for a destination address the UN-NAT is done first and then the ACL check is performed. This leads to the situation that you actually have to allow traffic from the external network to the local IP address and the local port.
So you probably have something like this
object network SERVER
host
nat (inside,outside) static interface service tcp 443 8443
or
host
nat (inside,outside) static service tcp 443 8443
So now your ACL rule should be
access-list permit tcp any object SERVER eq 443
as it matches the
access-list permit tcp any eq
Hope this helps
- Jouni
Overall Rating: 5 (1 ratings)
Correct Answer
Jouni Forss Sun, 02/09/2014 - 09:35
host
or
host
as it matches the
Hope this helps
- Jouni
