Warning message
Cisco IP Phone display- permanent line
Carlo Poggiarelli Mon, 02/10/2014 - 05:01
  • Green, 3000 points or more
Hi.
It should be the default behaviour in CUCM if you fill the "line text label" field
In CME you can use "System Message" under telephony service configuration to add " Your Current Options" message.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Carlo Poggiarelli Mon, 02/10/2014 - 06:06
Hi.
Have you filled the "Line Text" value under IP Phone's Directory number configuration page?
What is the ip phone firmware version?
Let usknow
Carlo
rikardkrvaric Mon, 02/10/2014 - 06:13
We have had this same issue with our phones.
We had to upgrade the firmware for the phones.
If it is currently BELOW 8.5, you must upgrade to 8.5 first, then, to 9.x...
Upgrade to 8.5+ will eliminate this silly line.
What is the firmware/Active Load you are running on the phone?
Related Content
