Certificate issue at Secondary ACS
Answered Question
Feb 10th, 2014
We have distributed ACS deployment model where Primary ACS can do the configuration role and secondary ACS is doing the monitoring role.
Our root certtificate was expired two days back and we have installed this on primary ACS bit forgot to install it on secondary ACS.
Due to this our some wirless useers were not able to connect with wireless with authentication fails messages.
So my question is , are both primary and secondary ACS accepting the AAA request and replying as we are using didtributted deployment model.
Or can share any cisco document which shows this ?
Correct Answer by Scott Fella about 3 years 6 months ago
The WLC will send authentication to the primary ACS server and only will use the secondary if there is no response from the primary. The WLC will not fail back to the primary unless the secondary fails to respond or if you have Fallback enabled in which the WLC will check if the primary is up.
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Mon, 02/10/2014 - 21:03
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Puneet Gupta Tue, 02/11/2014 - 00:01
Hi Scott
Thanks for the information
Exactly the same thing is happening .Now client are authenticated by secondary ACS not from primary ACS.
How can we make the primary ACS to work ? will it be distrupted ?
Puneet Gupta Tue, 02/11/2014 - 00:02
is there any way to check , when it was moven from primary to secondary ACS ?
Scott Fella Tue, 02/11/2014 - 05:32
  • Hall of Fame,
    2017 Wireless
You can see it in the WLC logs or if you issues a show radius summary. That will tell you which is active or not.
Puneet Gupta Tue, 02/11/2014 - 22:46
Is there any way in monitoring tab on ACS that can shows when autheniocation was shifted from primary to secondary ACS for those WLC's.
or any alarm.
