Catalyst 2960s Stacking with different IOS versions
Answered Question
Feb 11th, 2014
                   Hello Forum Team;
When adding a new switch with older ios version to an existing stack (flexstack) does the new switch will be able to join the stack?
Thanks in advanced!
Correct Answer by Ankur Arora about 3 years 6 months ago
In a stack/flexstack all the switches should have exact same IOS version, otherwise there will be a version mismatch on the stack and the new switch will not be able to join the stack.
The following Document contains more info:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/white_paper_c11-578928.html
Ankur
"Please rate the post if found useful"
Overall Rating: 5 (1 ratings)
fuhrersk8 Tue, 02/11/2014 - 13:50
Hello and thanks for the reply guys;
   Correct.  I just went trhough it. So im upgrading the new switches manually.
Thanks again for your great support.
Correct Answer
Ankur Arora Tue, 02/11/2014 - 13:20
  • Silver, 250 points or more
Ankur
Related Content
