Warning message
cucm 9.1 off-net ring cadence
Answered Question
Feb 11th, 2014
Off-net calls come in with a double-ring, where internal calls have a single ring.  Customer would like to stop this from happening.
is there a way to modify this cadence for off-net calls other than classifying all gateway / trunk calls as "off-net?"
Matt
Correct Answer by Carlo Poggiarelli about 3 years 6 months ago
Hi Matthew.
You can change Call Classification value under Service Parameters --> Cisco Callmanager "Device General" Section default is off-net.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Overall Rating: 5 (2 ratings)
Correct Answer
Carlo Poggiarelli Tue, 02/11/2014 - 21:39
  • Green, 3000 points or more
Hi Matthew.
Carlo
MATTHEW MIKTUS Wed, 02/12/2014 - 08:25
Carlo,
Thanks for the reply.
I was trying to figure out if there was a way to modify the cadence without marking every call "on-net."  Is there any detrement to having all calls marked on-net?
Matt
Carlo Poggiarelli Wed, 02/12/2014 - 12:52
Hi Matthew.
The only onption offered by CUCM is changing call classification to have the same ring cadence for all calls.
I don't see any particular issue on changing that value.
Carlo
Related Content
