Need help with configuring static IP for ASA 5505
Feb 11th, 2014
Hi Everyone,
I am new to the Cisco ASA platform but I have recently successfully managed to configure the ASA 5505 with dynamic IP. However, I am really struggling to configure the ASA 5505 with static IP. The ISP has given me the public IP address, subnet, DNS and Gateway IP. However, how do I puck those numbers into the ASA? I am really lost trying to get the internet to work...do I puck the public IP address for the "outside" IP? But if I do so, what do I give my "inside" IP? Is the Gateway IP and the public IP the same? The ISP told me it is the same thing...I am not sure how can I configure the ASA to merge it as a same thing
For illustration the IP addresses that I was given:
Gateway: 101.290.215.90/28
DNS: 210.101.1.60
WAN: 180.80.25.25/30
Appreciate if anyone can provide me any tips or pointers regarding this issue.
Here is the configure:
ASA Version 8.2(5)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 101.xxx.xxx.xxx 255.xxx.xxx.xxx
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
ftp mode passive
dns domain-lookup outside
dns domain-lookup inside
dns server-group DefaultDNS
name-server 203.xxx.xxx.xxx
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,inside) 101.127.251.32 101.127.251.32 netmask 255.255.255.240
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 101.127.251.32 255.255.255.240 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 101.xx.xx.xx-101.xx.xx.xx inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home reporting anonymous prompt 2
Overall Rating: 5 (2 ratings)
cadet alain Wed, 02/12/2014 - 05:37
  • Purple, 4500 points or more
interface Vlan2
nameif outside
security-level 0
no ip address dhcp setroute
ip address 180.80.25.25 255.255.255.252
no dhcpd auto_config outside
dhcpd dns 210.101.1.60
no name-server 203.xxx.xxx.xxx
name-server 210.101.1.60
route outside 0.0.0.0 0.0.0.0   x.x.x.x which is the next-hop  given by provider
But before doing this can you post following output from current config:
sh route outside
sh int ip br
as well as a quick diagram to really get sure i understand your topology correctly
Alain
ASALawenium Wed, 02/12/2014 - 05:45
Hi Alan,
Thanks for the reply.
I was wondering why did you choose to use the WAN as the outside IP address? Maybe I should have mentioned this earlier but the ISP provided me a Class B private IP address which would probably mean we cannot use this IP address?
Daxi
cadet alain Wed, 02/12/2014 - 05:52
I don't see any private address in the ones you provided as example and that's why I'd like a quick diagram to see exactly  what is your topology and what about the difference with current situation ? Same ISP but no more DHCP address on Wan interface connected to ISP modem ?
Alain
ASALawenium Wed, 02/12/2014 - 06:00
Hi Alain,
Appreciate your input very much.
Apologies about my illustration as it is not exactly accurate. The following illustration should be more accurate:
Gateway: 101.120.xxx.xxx/28
LAN: 101.120.xxx.xxx/28 (this is range of IPs)
DNS: 203.116.xxx.xx
PE IP: 172.xx.xx.51
CE IP: 172.xx.xx.52
With this set of IPs, how do one usually configure an ASA 5505 to have static IP?
Thanks again very much for your help.
cadet alain Wed, 02/12/2014 - 06:30
I still don't understand why you have a private range for CE-PE and public one for LAN,
the LAN is usually on inside and the WAN on outside so i would need a diagram to really understand and give you correct config.
Alain
