RA VPN connected, No decryption packet on the VPN Client
Feb 11th, 2014
Hi Team,
VPN is connected, Split tunnel is working properly.
Seeeing Encryption packets When try to connec the inside Servers, but no decryption packet on VPN client.
On ASA getting the error like,
Feb 12 2014 12:42:30: %ASA-4-402117: IPSEC: Received a non-IPSec packet (protocol= TCP) from 1.1.1.5 to 10.201.114.121.
Attached config file. PLease suggest.
Regards / Ramesh M
Poonam Garg Wed, 02/12/2014 - 02:24
  • Silver, 250 points or more
Hello Ramesh,
After going through your configuration, I noticed that you have not specified  the tunnel protocol under group-policy
group-policy vpn_group_policy internal
group-policy vpn_group_policy attributes
vpn-filter value VPN-ACCESS-IN
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split_tunnel_acl
Correction:
vpn-tunnel-protocol IPSec
Hope it will solve your issue.
Kindly rate and mark it correct if you find this solution working.
