02-12-2014 10:26 AM - edited 02-21-2020 07:29 PM
I installed a self-signed certificate to an ASA and then followed the AnyConnect wizard in ASDM.
Here is my config now: http://pastebin.com/raw.php?i=x4HibwSq
The address "vpn.<my_domain>" points to the WAN port of the ASA.
When users open "vpn.<my_domain>" in their browser, they see the ASDM launch screen.
Shouldn't they see the AnyConnect launch screen now?
02-12-2014 04:09 PM
I think your section:
webvpn enable outside
...needs to specify outside2 as the nameif outside is shutdown with no IP address.
Once that is done, if the FQDN resolves to your outside2 interface (180.70.242.6) it should work.
02-12-2014 04:56 PM
Ended up getting help from Cisco support and this is resolved. Not sure if that was the only thing that was wrong, but yes, you're definitely right about that interface name being off. Thanks!
