Warning message
Cisco 3750 ether channel configuration between Cisco and nortel
Answered Question
Feb 13th, 2014
I have cisco3750 switch i am trying to make ether channel on that switch below is the configuration i have done on same switch
interface GigabitEthernet1/0/23
switchport mode trunk
speed auto 10 100 1000
duplex full
channel-group 1 mode on
interface GigabitEthernet1/0/24
duplex full
spanning-tree bpdufilter enable
interface Port-channel1
Correct Answer by Dragan Ilic about 3 years 6 months ago
Something like this:
duplex full
channel-group 1 mode active
duplex full
spanning-tree bpdufilter enable - I would remove this or put same command on gi 1/0/23
Before everything I would delete intf port-ch 1, and remove commands for it under interfaces and then again put new config with commands which I provided and recreate intf port-ch 1...
BR,
Dragan
Correct Answer by Pierluigi Torriani about 3 years 6 months ago
to be sure you need to do some tests. LACP is standard IEEE supported on most vendors, you need to check the admin guide of Nortel devices for sure.
Remember that the configuration of ports member of an etherchannel must be identical as speed duplex. vlans etc...
Pier
Overall Rating: 5 (2 ratings)
Correct Answer
Pierluigi Torriani Thu, 02/13/2014 - 01:29
Pier
Dragan Ilic Thu, 02/13/2014 - 01:33
  • Silver, 250 points or more
Definitely must use LACP in this kind of environments...
BR,
Dragan
Correct Answer
Dragan Ilic Thu, 02/13/2014 - 02:21
duplex full
duplex full
BR,
Dragan
