02-13-2014 01:58 AM - edited 03-04-2019 10:20 PM
Thanks to give your insights on the below issue.
I need to route the same subnet on two routers (PC0 to communicate with PC1 and vice versa).
Host routes seem to do the trick, but is there any way to route the whole subnet? There are a lot of hosts in those subnets.
Thanks for all your help
Vijen
Solved! Go to Solution.
02-13-2014 02:16 AM
you can use static nat on both routers.
Alain
02-13-2014 02:16 AM
Alain
02-13-2014 02:21 AM
Hi Alain,
Thanks for your reply.
However, I guess static NATs would be one-to-one NATs.
Maybe i'm getting it wrong. Could you please provide an example so that I may better understand how to do the NAT?
Cheers,
Vijen
