02-13-2014 04:40 AM
I have users with MAC, they want to use Windows(by running as VM Instance) on Mac machine.
It is randomly working for few users only not all. Any comments on this will be helpful.
Most of the users get Client Error " Insufficient client resource"
Below are the config where it is not working
Mac OS: 10.7.4
Virtual Box Version: 4.1.22 r80657
Windows OS: Win 7 Pro SP1 64bit w/2 GB Memory
IE : ver 9.x
02-13-2014 05:12 AM
HI,
I think this is problem with video card virtualization on VM.
Maybe vmware workstation can this.
02-13-2014 07:32 AM
This is *heavily* dependent on the version of VSM you are running.
You will have little success with VSM 6.X, especially if VMR (Video Mixing Renderer http://en.wikipedia.org/wiki/Video_Mixing_Renderer ) is being utilized. It has historically been one of the few things that can't effectively be virtualized (hence the "Insufficient client resources" message). The VM can't instantiate the required Direct Show filer to render the video as the capability just isn't there in the VM.
You'll find that if the defined video stream doesn't leverage this renderer, the VM could possibly display it (MJPEG, etc..).
I haven't done much experimentation with VSM7 in a *virtualized* environment, but I do believe it is considerably more flexible.
Best of luck,
Scott Olsen
Solutions Specialist
Bulletproof Solutions Inc.
Web: www.bulletproofsi.com
02-27-2014 05:54 AM
Just an update that 7.5 appears to offer *beta* support for alternate platforms and browsers:
Cisco VSM Release 7.5 supports basic live video display using the Chrome and Firefox web browsers
on Windows and Linux workstations. The Chrome, Firefox and Safari browsers are supported on Mac
workstations.
This browser support is in “Beta” for Release 7.5 to gather feedback on the platforms and browsers that
are most important to users.
There are known limitations, so you should review the Release Notes yourself.
Cheers!
Scott Olsen
02-27-2014 07:29 AM
We have a system running 7.5 and Chrome is supported for live viewing only, None of the OSD (camera name, network status, control bar) are viewable which will definitely confuse some users IMHO.
03-12-2014 10:07 PM
In short you need the system requirements to view video in VSOM. Please provide what version VSM you are using and the system specs of the client and the specs that you are allowing the VM to utilize.
overall for 7.0 and above this is a good doc to get started with
06-22-2017 10:14 AM
i know this thread is old but VSM 7.9 now supports HTML 5 so VSOM will work on a MAC.
