Warning message
Unable to see FLOGI database on MDS 9148
Answered Question
Feb 13th, 2014
Just came accross with strange problem
In above scenairo I am not able see my blades on WWN on MDS 9148 switch where I can see WWN on Nexus 5548
Please help me to troubleshoot this issue
Amit Vyas
Correct Answer by Walter Dey about 3 years 6 months ago
Hi Amit
What are the flogi showing up going over fc 1/29 and 1/30 ?
Your problem is clear: it's a routing issue ? how can a initiator pwwn eg. in VSAN 100 decide, on which port he should go Northbound ?
The solution:
Create 2 additional VSAN's, e.g. 102 and 103; 100/101 will be used to reach N5k, 102/103 to reach MDS; you of course need 2 additional vhba's, one in 102, resp 103.
Hopefully you have done your zoning with device-alias (enhanced); then this change will be easy.
Another ugly solution would be to use static ping groups, which is hardly used, a management and scalabilty nightmare, and therefore not recommended.
Good luck
Walter.
Overall Rating: 5 (1 ratings)
Walter Dey Thu, 02/13/2014 - 05:55
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Unified Computing, Storage Networking
I assume UCS is in FC NPV mode ?
Did you configure the MDS in NPIV mode ?
are FC ports on the UCS in the proper VSAN ? eg. are the FC links from UCS to MDS up ?
Give us from each fabric interconnects the output of the following NX-OS commands: "show npv status"
And on the N5k, and MDS "show flogi database"
Amit Vyas Thu, 02/13/2014 - 11:10
Please find my response below for the questions you have asked
I assume UCS is in FC NPV mode ? - Yes
Did you configure the MDS in NPIV mode ? - Yes
are FC ports on the UCS in the proper VSAN ? eg. are the FC links from UCS to MDS up ? - Yes, Links are UP on UCSM
Give us from each fabric interconnects the output of the following NX-OS commands: "show npv status" - Result below
Switch-A(nxos)# show npv status
npiv is enabled
disruptive load balancing is disabled
External Interfaces:
  Interface: fc1/31, VSAN:  100, FCID: 0xa40020, State: Up
  Interface: fc1/32, VSAN:  100, FCID: 0xa40000, State: Up
  Interface: fc2/15, VSAN:  100, FCID: 0x180100, State: Up
  Interface: fc2/16, VSAN:  100, FCID: 0x180300, State: Up
  Number of External Interfaces: 4
Server Interfaces:
  Interface: vfc2995, VSAN:  100, State: Up
  Interface: vfc3001, VSAN:  100, State: Up
  Interface: vfc3003, VSAN:  100, State: Up
  Interface: vfc3005, VSAN:  100, State: Up
  Interface: vfc3007, VSAN:  100, State: Up
  Interface: vfc3009, VSAN:  100, State: Up
  Interface: vfc3011, VSAN:  100, State: Up
  Interface: vfc3013, VSAN:  100, State: Up
  Interface: vfc3015, VSAN:  100, State: Up
  Interface: vfc3017, VSAN:  100, State: Up
  Interface: vfc3167, VSAN:  100, State: Up
  Interface: vfc3191, VSAN:  100, State: Up
  Interface: vfc3213, VSAN:  100, State: Up
  Interface: vfc3237, VSAN:  100, State: Up
  Interface: vfc3283, VSAN:  100, State: Up
  Interface: vfc3307, VSAN:  100, State: Up
  Interface: vfc3331, VSAN:  100, State: Up
  Interface: vfc3353, VSAN:  100, State: Up
  Interface: vfc3375, VSAN:  100, State: Up
  Interface: vfc3397, VSAN:  100, State: Up
  Interface: vfc3441, VSAN:  100, State: Up
  Interface: vfc3463, VSAN:  100, State: Up
  Interface: vfc3485, VSAN:  100, State: Up
  Interface: vfc3507, VSAN:  100, State: Up
  Interface: vfc3529, VSAN:  100, State: Up
  Interface: vfc3551, VSAN:  100, State: Up
  Interface: vfc3573, VSAN:  100, State: Up
  Interface: vfc3595, VSAN:  100, State: Up
  Interface: vfc3617, VSAN:  100, State: Up
  Interface: vfc3639, VSAN:  100, State: Up
  Interface: vfc3661, VSAN:  100, State: Up
  Interface: vfc3683, VSAN:  100, State: Up
  Interface: vfc3705, VSAN:  100, State: Up
  Interface: vfc3727, VSAN:  100, State: Up
  Interface: vfc3749, VSAN:  100, State: Up
  Interface: vfc3771, VSAN:  100, State: Up
  Interface: vfc3793, VSAN:  100, State: Up
  Interface: vfc3841, VSAN:  100, State: Up
  Number of Server Interfaces: 38
Switch-A(nxos)#
Switch-B(nxos)# show npv status
npiv is enabled
  Interface: fc1/31, VSAN:  101, FCID: 0x3c0000, State: Up
  Interface: fc1/32, VSAN:  101, FCID: 0x3c0020, State: Up
  Interface: fc2/15, VSAN:  101, FCID: 0x0c0200, State: Up
  Interface: fc2/16, VSAN:  101, FCID: 0x0c0300, State: Up
Server Interfaces:
  Interface: vfc2996, VSAN:  101, State: Up
  Interface: vfc3002, VSAN:  101, State: Up
  Interface: vfc3004, VSAN:  101, State: Up
  Interface: vfc3006, VSAN:  101, State: Up
  Interface: vfc3008, VSAN:  101, State: Up
  Interface: vfc3010, VSAN:  101, State: Up
  Interface: vfc3012, VSAN:  101, State: Up
  Interface: vfc3014, VSAN:  101, State: Up
  Interface: vfc3016, VSAN:  101, State: Up
  Interface: vfc3018, VSAN:  101, State: Up
  Interface: vfc3168, VSAN:  101, State: Up
  Interface: vfc3192, VSAN:  101, State: Up
  Interface: vfc3214, VSAN:  101, State: Up
  Interface: vfc3238, VSAN:  101, State: Up
  Interface: vfc3284, VSAN:  101, State: Up
  Interface: vfc3308, VSAN:  101, State: Up
  Interface: vfc3332, VSAN:  101, State: Up
  Interface: vfc3354, VSAN:  101, State: Up
  Interface: vfc3376, VSAN:  101, State: Up
  Interface: vfc3398, VSAN:  101, State: Up
  Interface: vfc3442, VSAN:  101, State: Up
  Interface: vfc3464, VSAN:  101, State: Up
  Interface: vfc3486, VSAN:  101, State: Up
  Interface: vfc3508, VSAN:  101, State: Up
  Interface: vfc3530, VSAN:  101, State: Up
  Interface: vfc3552, VSAN:  101, State: Up
  Interface: vfc3574, VSAN:  101, State: Up
  Interface: vfc3596, VSAN:  101, State: Up
  Interface: vfc3618, VSAN:  101, State: Up
  Interface: vfc3640, VSAN:  101, State: Up
  Interface: vfc3662, VSAN:  101, State: Up
  Interface: vfc3684, VSAN:  101, State: Up
  Interface: vfc3706, VSAN:  101, State: Up
  Interface: vfc3728, VSAN:  101, State: Up
  Interface: vfc3750, VSAN:  101, State: Up
  Interface: vfc3772, VSAN:  101, State: Up
  Interface: vfc3794, VSAN:  101, State: Up
  Interface: vfc3842, VSAN:  101, State: Up
Switch-B(nxos)#
And on the N5k, and MDS "show flogi database" - Result Below
MDS-9148-SW1# show flogi database
INTERFACE        VSAN    FCID           PORT NAME               NODE NAME
fc1/1            100   0x180000  50:06:01:60:3e:e0:5a:27 50:06:01:60:be:e0:5a:27
fc1/2            100   0x180200  50:06:01:69:3e:e0:5a:27 50:06:01:60:be:e0:5a:27
fc1/3            100   0x180100  20:4f:54:7f:ee:a0:97:c0 20:c8:54:7f:ee:a0:97:c1
fc1/4            100   0x180300  20:50:54:7f:ee:a0:97:c0 20:c8:54:7f:ee:a0:97:c1
Total number of flogi = 4.
MDS-9148-SW2# show flogi database
fc1/1            101   0x0c0000  50:06:01:68:3e:e0:5a:27 50:06:01:60:be:e0:5a:27
fc1/2            101   0x0c0100  50:06:01:61:3e:e0:5a:27 50:06:01:60:be:e0:5a:27
fc1/3            101   0x0c0200  20:4f:54:7f:ee:a0:9a:80 20:c9:54:7f:ee:a0:9a:81
fc1/4            101   0x0c0300  20:50:54:7f:ee:a0:9a:80 20:c9:54:7f:ee:a0:9a:81
N5K-Primary_SW# show flogi database
fc1/29           100   0xa40001  20:00:00:25:b5:00:00:1f 20:00:00:25:b5:00:00:7e
fc1/29           100   0xa40004  20:00:00:25:b5:00:00:7c 20:00:00:25:b5:00:00:5c
fc1/29           100   0xa40006  20:00:00:25:b5:00:00:7a 20:00:00:25:b5:00:00:4a
fc1/29           100   0xa40009  20:00:00:25:b5:00:00:48 20:00:00:25:b5:00:00:38
fc1/29           100   0xa4000a  20:00:00:25:b5:00:00:67 20:00:00:25:b5:00:00:57
fc1/29           100   0xa4000c  20:00:00:25:b5:00:00:26 20:00:00:25:b5:00:00:16
fc1/29           100   0xa40012  20:00:00:25:b5:00:00:02 20:00:00:25:b5:00:00:6b
fc1/29           100   0xa40013  20:00:00:25:b5:00:00:41 20:00:00:25:b5:00:00:2f
fc1/29           100   0xa40020  20:1f:54:7f:ee:a0:97:c0 20:64:54:7f:ee:a0:97:c1
fc1/29           100   0xa40021  20:00:00:25:b5:00:00:7f 20:00:00:25:b5:00:00:5e
fc1/29           100   0xa40023  20:00:00:25:b5:00:00:5d 20:00:00:25:b5:00:00:0e
fc1/29           100   0xa40024  20:00:00:25:b5:00:00:1d 20:00:00:25:b5:00:00:5f
fc1/29           100   0xa40026  20:00:00:25:b5:00:00:0b 20:00:00:25:b5:00:00:1b
fc1/29           100   0xa40028  20:00:00:25:b5:00:00:59 20:00:00:25:b5:00:00:49
fc1/29           100   0xa4002a  20:00:00:25:b5:00:00:18 20:00:00:25:b5:00:00:08
fc1/29           100   0xa4002b  20:00:00:25:b5:00:00:37 20:00:00:25:b5:00:00:27
fc1/29           100   0xa4002e  20:00:00:25:b5:00:00:15 20:00:00:25:b5:00:00:05
fc1/29           100   0xa4002f  20:00:00:25:b5:00:00:34 20:00:00:25:b5:00:00:24
fc1/29           100   0xa40031  20:00:00:25:b5:00:00:72 20:00:00:25:b5:00:00:4c
fc1/29           100   0xa40032  20:00:00:25:b5:00:00:32 20:00:00:25:b5:00:00:22
fc1/30           100   0xa40000  20:20:54:7f:ee:a0:97:c0 20:64:54:7f:ee:a0:97:c1
fc1/30           100   0xa40002  20:00:00:25:b5:00:00:1e 20:00:00:25:b5:00:00:6d
fc1/30           100   0xa40003  20:00:00:25:b5:00:00:3d 20:00:00:25:b5:00:00:6e
fc1/30           100   0xa40005  20:00:00:25:b5:00:00:4b 20:00:00:25:b5:00:00:2b
fc1/30           100   0xa40007  20:00:00:25:b5:00:00:1a 20:00:00:25:b5:00:00:79
fc1/30           100   0xa40008  20:00:00:25:b5:00:00:29 20:00:00:25:b5:00:00:19
fc1/30           100   0xa4000b  20:00:00:25:b5:00:00:07 20:00:00:25:b5:00:00:76
fc1/30           100   0xa4000d  20:00:00:25:b5:00:00:45 20:00:00:25:b5:00:00:35
fc1/30           100   0xa4000e  20:00:00:25:b5:00:00:64 20:00:00:25:b5:00:00:54
fc1/30           100   0xa4000f  20:00:00:25:b5:00:00:04 20:00:00:25:b5:00:00:73
fc1/30           100   0xa40011  20:00:00:25:b5:00:00:52 20:00:00:25:b5:00:00:3c
fc1/30           100   0xa40022  20:00:00:25:b5:00:00:2e 20:00:00:25:b5:00:00:7d
fc1/30           100   0xa40025  20:00:00:25:b5:00:00:0c 20:00:00:25:b5:00:00:1c
fc1/30           100   0xa40027  20:00:00:25:b5:00:00:2a 20:00:00:25:b5:00:00:3a
fc1/30           100   0xa40029  20:00:00:25:b5:00:00:78 20:00:00:25:b5:00:00:68
fc1/30           100   0xa4002c  20:00:00:25:b5:00:00:56 20:00:00:25:b5:00:00:46
fc1/30           100   0xa4002d  20:00:00:25:b5:00:00:75 20:00:00:25:b5:00:00:65
fc1/30           100   0xa40030  20:00:00:25:b5:00:00:53 20:00:00:25:b5:00:00:43
fc1/30           100   0xa40033  20:00:00:25:b5:00:00:61 20:00:00:25:b5:00:00:5b
fc1/31           100   0xa400ef  50:06:01:60:3e:a0:13:d5 50:06:01:60:be:a0:13:d5
fc1/32           100   0xa401ef  50:06:01:68:3e:a0:13:d5 50:06:01:60:be:a0:13:d5
Total number of flogi = 41.
N5K-Primary_SW#
N5K-Secondary_SW# show flogi database
fc1/29           101   0x3c0000  20:1f:54:7f:ee:a0:9a:80 20:65:54:7f:ee:a0:9a:81
fc1/29           101   0x3c0002  20:00:00:25:b5:00:00:4e 20:00:00:25:b5:00:00:7d
fc1/29           101   0x3c0003  20:00:00:25:b5:00:00:4d 20:00:00:25:b5:00:00:0e
fc1/29           101   0x3c0005  20:00:00:25:b5:00:00:2c 20:00:00:25:b5:00:00:1c
fc1/29           101   0x3c0008  20:00:00:25:b5:00:00:69 20:00:00:25:b5:00:00:49
fc1/29           101   0x3c000a  20:00:00:25:b5:00:00:28 20:00:00:25:b5:00:00:08
fc1/29           101   0x3c000b  20:00:00:25:b5:00:00:47 20:00:00:25:b5:00:00:27
fc1/29           101   0x3c000e  20:00:00:25:b5:00:00:25 20:00:00:25:b5:00:00:05
fc1/29           101   0x3c000f  20:00:00:25:b5:00:00:44 20:00:00:25:b5:00:00:24
fc1/29           101   0x3c0010  20:00:00:25:b5:00:00:63 20:00:00:25:b5:00:00:43
fc1/29           101   0x3c0012  20:00:00:25:b5:00:00:42 20:00:00:25:b5:00:00:22
fc1/29           101   0x3c0021  20:00:00:25:b5:00:00:0f 20:00:00:25:b5:00:00:7e
fc1/29           101   0x3c0022  20:00:00:25:b5:00:00:3e 20:00:00:25:b5:00:00:6d
fc1/29           101   0x3c0024  20:00:00:25:b5:00:00:6c 20:00:00:25:b5:00:00:5c
fc1/29           101   0x3c0026  20:00:00:25:b5:00:00:6a 20:00:00:25:b5:00:00:4a
fc1/29           101   0x3c0027  20:00:00:25:b5:00:00:0a 20:00:00:25:b5:00:00:79
fc1/29           101   0x3c0029  20:00:00:25:b5:00:00:58 20:00:00:25:b5:00:00:38
fc1/29           101   0x3c002c  20:00:00:25:b5:00:00:36 20:00:00:25:b5:00:00:16
fc1/29           101   0x3c002e  20:00:00:25:b5:00:00:74 20:00:00:25:b5:00:00:54
fc1/29           101   0x3c0033  20:00:00:25:b5:00:00:51 20:00:00:25:b5:00:00:2f
fc1/30           101   0x3c0001  20:00:00:25:b5:00:00:6f 20:00:00:25:b5:00:00:5e
fc1/30           101   0x3c0004  20:00:00:25:b5:00:00:0d 20:00:00:25:b5:00:00:5f
fc1/30           101   0x3c0006  20:00:00:25:b5:00:00:3b 20:00:00:25:b5:00:00:1b
fc1/30           101   0x3c0007  20:00:00:25:b5:00:00:5a 20:00:00:25:b5:00:00:3a
fc1/30           101   0x3c0009  20:00:00:25:b5:00:00:09 20:00:00:25:b5:00:00:68
fc1/30           101   0x3c000c  20:00:00:25:b5:00:00:66 20:00:00:25:b5:00:00:46
fc1/30           101   0x3c000d  20:00:00:25:b5:00:00:06 20:00:00:25:b5:00:00:65
fc1/30           101   0x3c0011  20:00:00:25:b5:00:00:03 20:00:00:25:b5:00:00:4c
fc1/30           101   0x3c0013  20:00:00:25:b5:00:00:71 20:00:00:25:b5:00:00:5b
fc1/30           101   0x3c0020  20:20:54:7f:ee:a0:9a:80 20:65:54:7f:ee:a0:9a:81
fc1/30           101   0x3c0023  20:00:00:25:b5:00:00:2d 20:00:00:25:b5:00:00:6e
fc1/30           101   0x3c0025  20:00:00:25:b5:00:00:7b 20:00:00:25:b5:00:00:2b
fc1/30           101   0x3c0028  20:00:00:25:b5:00:00:39 20:00:00:25:b5:00:00:19
fc1/30           101   0x3c002a  20:00:00:25:b5:00:00:77 20:00:00:25:b5:00:00:57
fc1/30           101   0x3c002b  20:00:00:25:b5:00:00:17 20:00:00:25:b5:00:00:76
fc1/30           101   0x3c002d  20:00:00:25:b5:00:00:55 20:00:00:25:b5:00:00:35
fc1/30           101   0x3c002f  20:00:00:25:b5:00:00:14 20:00:00:25:b5:00:00:73
fc1/30           101   0x3c0031  20:00:00:25:b5:00:00:62 20:00:00:25:b5:00:00:3c
fc1/30           101   0x3c0032  20:00:00:25:b5:00:00:12 20:00:00:25:b5:00:00:6b
fc1/31           101   0x3c00ef  50:06:01:61:3e:a0:13:d5 50:06:01:60:be:a0:13:d5
fc1/32           101   0x3c01ef  50:06:01:69:3e:a0:13:d5 50:06:01:60:be:a0:13:d5
N5K-Secondary_SW#
Correct Answer
Walter Dey Thu, 02/13/2014 - 12:15
Hi Amit
The solution:
Good luck
Walter.
Amit Vyas Thu, 02/13/2014 - 13:06
Hi Walter,
Thanks for your reply
I did the same thing what you have mentioned, while doing the troubleshooting I also thought the same the hwo initiator will decide on which port traffic has to be sent
Thanks once again for your reply it really cleared the doubt
Amit Vyas
