Warning message
NGN Firewall Features
Answered Question
Feb 14th, 2014
Dear Team,
I need to purchase a Firewall with CX, IPS, AVC and WSE. I am looking for ASA5512-X Firewall. I also need to have comprehensive Web Reporting and Antivirus updates.
Please guide me which Model should I go for.
Farhan.
Correct Answer by Marvin Rhoads about 3 years 6 months ago
That covers the hardware and NGFW susbscription-based services.
For any ASA that has a subscription-based service attached, Cisco requires that the base unit have SMARTnet support. Your reseller can advise you as to the options and associated SKUs (part numbers) for the support contract.
Overall Rating: 5 (1 ratings)
Marvin Rhoads Fri, 02/14/2014 - 06:01
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Cisco no longer does any Anti-Virus directly on the firewall like they used to with the AIP module.
Other than that, if you just order our firewall with the license for IPS, AVC and WSE you will be covered. Your reseller should be able to advise you on the exact ordering information but it is generally described in the product data sheet here (see bottom of table 4).
Syed Farhan Ali Sun, 02/16/2014 - 22:37
Dear Marvin,
I will be ordering the following and I believe the requirements will be covered as per last message:
ASA5512-SSD120-K9
ASA5512AWI1Y
Please advise.
Farhan.
Correct Answer
Marvin Rhoads Mon, 02/17/2014 - 06:14
  • Hall of Fame,
