CUCM Upgrade : Pg Jtapi upgrade question
Answered Question
Feb 14th, 2014
We're planning to upgrade our CUCM from 8.5 to 8.6.2 and I am finding some contradicting information with regards to upgrading the jtapi client on the PG's so that they match the CUCM version. So just wanted to check with you guys what would be the correct procedure?
option 1
Stop pg processes
upgrade jtapi client
reboot
start pg processes
option 2
stop pg processes
uninstall old jtapi client
install new jtapi client
reboot
start pg processes
Thanks in advance for your insights.
Rgds,
Jeroen
Correct Answer by david.macias about 3 years 6 months ago
I don't think a reboot is required either if you want to do this faster.
david
Correct Answer by Chris Deren about 3 years 6 months ago
I concur and don't forget to do this on side B as well.
Chris
Correct Answer by Gergely Szabo about 3 years 6 months ago
option 1 would do.
G.
Overall Rating: 4.8 (4 ratings)
Correct Answer
Gergely Szabo Fri, 02/14/2014 - 03:07
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
option 1 would do.
G.
Correct Answer
Chris Deren Fri, 02/14/2014 - 05:27
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Chris
Correct Answer
david.macias Fri, 02/14/2014 - 05:34
  • Blue, 1500 points or more
david
jeroenhermans Fri, 02/14/2014 - 05:42
Hi Guys,
Thanks for all your replies.
I have in the mean time also tried it on a lab enviroment and can confirm option 1 works (even without a reboot indeed).
Jeroen
david.macias Fri, 02/14/2014 - 09:33
Thank you for confirming and providing an update!
david
