Route calls based on RFC 3261 SIP “From” header display name
Feb 14th, 2014
HI,
I'd like to be able to route \ translate incoming calls based on the following field in the sip message.
So calls from the label bob are translated to a specified number in cucm.
So why do I want to do this?
Currently I'm using Skype connect and it allows for multiple Skype business accounts to be attached. However when a call comes into CUBE it currently routes based on the Skype number which is the same for each business account.
My end game would be to have the one sip connect profile and the following two Skype accounts attached
Example
Bookings – routes to one queue
Flights – routes to another queue
I hoping not to have to go down the normalized script path. However if someone thinks it is the answer and some good examples please feel free to help out.
Ayodeji Okanlawon Fri, 02/14/2014 - 20:08
  • Cisco Designated VIP,
    2017 IP Telephony
Andrew,
You route calls based on the request URI not the To or From headers. Cisco devices (CUCM, Gateway) only route calls based on the RURI...Thats is the INVITE SIP:[email protected]...This similar to how you route calls based on the called number not the calling number
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Andrew Grech Fri, 02/14/2014 - 23:31
Thanks aokanlawon,
I'll check the RURI and see if its any different between SKYPE user names. At the moment I'm translating the incomming number from skype to one of my own indial numbers.
Called Skypename>Skype connect>SIP>Cube>SIP>UCM>Translate incomming called number called>CCX
