cisco cat 4507R with sup iv IOS upgrade problem
Feb 16th, 2014
hi all,
I have cisco catalyst WS-C4507R with suoervisor (WS-X4515) with IOS (cat4000-I9K91S-M) I need to upgrade it to the latest IOS (150)
when I download the IOS from cisco site and copied it on the bootflash: and force it to boot from this image (this displayed in the output of show bootvar)
I reboot the box then when started up I found that it not booted from the required IOS and boot from the old IOS.
any help please
Reza Sharifi Sun, 02/16/2014 - 07:35
  • Cisco Designated VIP,
    2017 LAN
First check with "sh boot"  command, most likely the old version is still in the boot variable.
Than deleted the old boot variable command and than add the new one, save and reboot.
no system bootflash
system bootflash
Mohamed Sayed Sun, 02/16/2014 - 11:49
I checked show bootvar, I found that the next boot will be from the version 150 and after I reload the switch I found it still not boot from the required version ??
what may be the problem ???
Reza Sharifi Sun, 02/16/2014 - 12:43
    2017 LAN
Did you actually try these command?
no system bootflash
system bootflash
wr
reload
Mohamed Sayed Sun, 02/16/2014 - 12:55
yeah
I tried these command more than one time and the result is the same ??
Reza Sharifi Sun, 02/16/2014 - 17:35
    2017 LAN
Can you post the output of "show ver"?
Mohamed Sayed Mon, 02/17/2014 - 09:04
Dear Reza,
I solved the problem
thanks alot for your kindly support.
the problem history:
-from the release note of the IOS it was neccessary to upgrade the ROMMON IOS to another version.
-config-register was 0x2101 I changed it to 0x2102
-upgrade the IOS
it upgraded successfully
I appreciate you
Related Content
