Warning message
E1 line configuration on iOS
Feb 17th, 2014
Hi All,
I have a cisco router c2600 version 12.4T. I'm trying to configure the E1 on that router and connectto an eFax server. but it seems that there is some thing wrong in the configuration. Are there anything wrong in the config ??
Current configuration : 2759 bytes
version 12.4
hostname MAA-FAX
boot-start-marker
boot system flash
boot system flash c2600-ipvoice-mz.124-15.T14.bin
boot-end-marker
card type e1 1 1
enable secret 5 $1$Eu5N$LNIs2iojGJB.VUSeYS45T1
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip domain name main.knpcdom.net
isdn switch-type primary-net5
voice-card 1
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729br8
archive
log config
  hidekeys
controller E1 1/0
pri-group timeslots 1-31
controller E1 1/1
interface FastEthernet0/0
ip address x.x.x.x(voice GW ip) 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial1/1:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 x.x.x.x(Voice GW ip -last digit is 1)
no ip http server
no logging trap
control-plane
voice-port 1/0:15
voice-port 1/1:15
dial-peer voice 100 voip
preference 2
destination-pattern [1234567890]...
voice-class codec 1
session target ipv4:x.x.x.x (the eFax server ip)
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 200 pots
destination-pattern 2.......
port 1/0:15
dial-peer voice 101 voip
preference 1
voice-class codec 1
session target ipv4:x.x.x.x (the eFax backup server ip)
no vad
dial-peer voice 10 voip
translation-profile incoming rightfax
voice-class codec 1
incoming called-number 2.......
no vad
dial-peer voice 2 pots
incoming called-number .
direct-inward-dial
dial-peer voice 102 voip
destination-pattern 8...
session target ipv4:x.x.x.x (CUCM ip)
codec g711ulaw
no vad
dial-peer voice 103 voip
preference 1
session target ipv4:x.x.x.x (CUCM backup ip)
codec g711ulaw
no vad
dial-peer voice 1 voip
voice-class codec 1
no vad
line con 0
password ******
login
line aux 0
line vty 0 4
password ******
login
transport input all
end
Thank alot
Richard Burts Thu, 02/20/2014 - 07:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I am surprised to see encapsulation hdlc on the serial interfaces. Are you sure that the server is processing hdlc?
Rick
Dragan Ilic Fri, 02/21/2014 - 01:21
  • Silver, 250 points or more
Can you post output of "debug isdn q921" and "debug isdn q931" during attempt to make a call?
HTH,
Dragan
