RV220W VPN
troyr7301
Ugh. I've spent endless hours trying to get the VPN to work. I've done all the recommended actions for QuickVPN (run as Vista SP2, disable avast, enable windows firewall, disable windows defender, create windows ICMPv4 rules, turned on IPSEC services, disabled other network adapters) but I can NEVER connect. It always comes up with waiting for network.
I set up PPTP today. And it worked partially. I was able to access the RV220W but unable to browse any other networked devices or even access the internet. I ran the windows diagnostic tool and it said it was a DNS issue on the remote side.
Can someone please guide me before I end up ripping this device off the network? Much appreciated!
mpyhala
Level 7
Level 7
Troy,
What is your OS?
Does the RV220W have a static WAN IP?
Who is the ISP?
Where are you connecting FROM?
Does the local router have a different IP than the RV2220W?
Is the RV220W on the latest firmware?
- Marty
