Warning message
EEM TCL for interface commands
Feb 17th, 2014
I am working on a script that will make interface changes.  I am trying to do the following:
1) save the output from the following command:  #show cdp nei detail | i Interface
2) this will most likely give a list of interfaces some of which will be repeated.  If the interface is listed more than once then i would like to remove the
    repeated interface.  (note i am not concerned about the outgoing interface)
3)using the above information i would then like to make configuration to the interfaces with the following commands
     #config t
     #interface $intf
     #no mls qos vlan-based
     #mls qos trust dscp
i have started this script (please see attached file) and would really appreciate some assistance especially with how to eliminate multiple instances of the same interface.
thanks!!
Daniel Frey Mon, 02/17/2014 - 13:26
  • Cisco Employee,
Add "set summary [lsort -unique $summary] " to your script after creating $summary.
if [catch {cli_exec $cli1(fd) "show cdp neighbors detail | include Interface" } summary ] {
    error $summary $errorInfo
set lines [split $summary "\n"]
ect....
Dan
bryan totten Fri, 03/07/2014 - 09:14
I am having issues running scripts on my 3750x.  One of the few commands i am getting to work is the
router(tcl)#puts "testing this command"
most all other commands are not working for example:  ios_config, set
I am attaching a file with more details.  Any help would be greatly appreciated!
Joe Clarke Sat, 03/08/2014 - 13:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Tclsh doesn't work with command authorization.  If you need to use command authz, you will need to switch to EEM Tcl and configure:
event manager session cli username USER
Where USER is a user authorized to run all of the CLI commands.  Since this thread doesn't seem to be applicable to what you're doing, I recommend you start a new one if you require more help.
Related Content
