Warning message
problem vpn "tunnel is not up"
Feb 18th, 2014
hi all ,
please i have a problem in my router cisco2901 the tunnel is not set betwen router mlps and router dmvpn
Here is the configuration on the router DMVPN
hostname RT_BMCI_
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.150-1.M7.bin
boot-end-marker
enable secret 5 $1$..zF$.jJDav4YAlITDqs3p/XFA.
no aaa new-model
no ipv6 cef
no ip source-route
ip cef
ip vrf F-VRF
rd 65000:1
no ip domain lookup
ip domain name ma.net.intra
license udi pid CISCO2901/K9 sn FCZ171391DH
username local password 7 082D434D0815
username bmci password 0 bmci
redundancy
crypto keyring F-VRF_KEYRING vrf F-VRF
  description clef pour vrf F-VRF
  pre-shared-key address 10.74.164.2 key dmbmcivpn
  pre-shared-key address 10.74.164.3 key dmbmcivpn
crypto isakmp policy 1
encr aes 192
authentication pre-share
group 2
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 10 periodic
crypto ipsec security-association replay window-size 1024
crypto ipsec transform-set F-VRF_TSET esp-aes 192 esp-md5-hmac
mode transport
crypto ipsec profile F-VRF_PROFILE
set transform-set F-VRF_TSET
interface Loopback0
ip address 10.74.249.15 255.255.255.255
interface Loopback10
description loopback src des tunnels
ip vrf forwarding F-VRF
ip address 10.74.165.15 255.255.255.255
interface Tunnel100
description tunnel dmvpn
dampening
bandwidth 2048
-ip address 10.74.161.6 255.255.252.0
no ip redirects
ip mtu 1400
ip nhrp authentication PASS-1
ip nhrp map multicast dynamic
ip nhrp map multicast 10.74.164.3
ip nhrp map 10.74.160.3 10.74.164.3
ip nhrp map multicast 10.74.164.2
ip nhrp map 10.74.160.2 10.74.164.2
ip nhrp network-id 1
ip nhrp nhs 10.74.160.2
ip nhrp nhs 10.74.160.3
ip nhrp registration no-unique
ip nhrp registration timeout 120
ip tcp adjust-mss 1360
no ip split-horizon
load-interval 30
qos pre-classify
cdp enable
tunnel source Loopback10
tunnel mode gre multipoint
tunnel key 0
tunnel vrf F-VRF
tunnel protection ipsec profile F-VRF_PROFILE shared
interface GigabitEthernet0/0
ip address 10.74.146.150 255.255.255.224
ip helper-address 10.74.240.113
ip helper-address 10.74.240.121
duplex auto
speed auto
interface GigabitEthernet0/1
description ### Connected to Maroc Telecom ###
ip address 10.74.152.219 255.255.255.254
ip access-group 150 in
duplex auto
speed auto
no cdp enable
router eigrp 4
-address-family ipv4 vrf F-VRF
  network 10.74.0.0 0.0.255.255
  passive-interface default
  autonomous-system 4
  eigrp router-id 10.74.165.15
exit-address-family
no passive-interface Tunnel100
eigrp router-id 10.74.249.15
eigrp stub connected
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 10.74.0.0 255.255.0.0 GigabitEthernet0/1
access-list 150 remark *** Autorisation du traffic EIGRP ***
access-list 150 permit eigrp 10.74.0.0 0.0.255.255 any
access-list 150 remark *** Autorisation du traffic entrant ISAKMP et ESP ***
access-list 150 permit udp any 10.74.0.0 0.0.255.255 eq isakmp
access-list 150 permit esp any 10.74.0.0 0.0.255.255
access-list 150 remark *** Autorisation du traffic ping, Telnet et Ssh ***
access-list 150 permit icmp 10.74.0.0 0.0.255.255 10.74.0.0 0.0.255.255 echo-reply
access-list 150 permit tcp 10.74.0.0 0.0.255.255 10.74.0.0 0.0.255.255 eq telnet
access-list 150 permit tcp 10.74.0.0 0.0.255.255 10.74.0.0 0.0.255.255 eq 22
access-list 150 remark *** Autorisation du traffic inter loopback ***
access-list 150 permit ip 10.74.164.0 0.0.3.255 10.74.164.0 0.0.3.255
access-list 150 remark *** GRE point a point avec l.autre hub ***
access-list 150 permit gre host 10.74.250.10 host 10.74.250.9
access-list 150 permit gre host 10.74.250.9 host 10.74.250.10
access-list 150 remark *** Allow SSH traffic inbound ***
access-list 150 permit 22 host 10.74.164.2 10.74.0.0 0.0.255.255
access-list 150 permit 22 host 10.74.164.3 10.74.0.0 0.0.255.255
snmp-server host 10.74.0.105 bmciro
line con 0
line aux 0
line vty 0 4
exec-timeout 0 0
password 7 110B14061E
login
transport input ssh
line vty 5 15
exec-timeout 0 0
password 7 094E430A10
login
transport input telnet
scheduler allocate 20000 1000
RT_BMCI_#sh dmvpn detail
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
        N - NATed, L - Local, X - No Socket
        # Ent --> Number of NHRP entries with same NBMA peer
        NHS Status: E --> Expecting Replies, R --> Responding
        UpDn Time --> Up or Down Time for a Tunnel
Interface Tunnel100 is up/up, Addr. is 10.74.161.6, VRF ""
   Tunnel Src./Dest. addr: 10.74.165.15/MGRE, Tunnel VRF "F-VRF"
   Protocol/Transport: "multi-GRE/IP", Protect "F-VRF_PROFILE"
   Interface State Control: Disabled
IPv4 Registration Timer: 120 seconds
IPv4 NHS: 10.74.160.2  E
10.74.160.3  E
Type:Spoke, Total NBMA Peers (v4/v6): 2
# Ent  Peer NBMA Addr Peer Tunnel Add State  UpDn Tm Attrb    Target Network
    1    10.74.164.2     10.74.160.2   IKE 01:48:03    S     10.74.160.2/32
    1    10.74.164.3     10.74.160.3  NHRP 01:48:03    S     10.74.160.3/32
Crypto Session Details:
Interface: Tunnel100
Session: [0x3121B7E4]
  Crypto Session Status: DOWN
  fvrf: F-VRF,    IPSEC FLOW: permit 47 host 10.74.165.15 host 10.74.164.2
        Active SAs: 0, origin: crypto map
        Inbound:  #pkts dec'ed 0 drop 0 life (KB/Sec) 0/0
        Outbound: #pkts enc'ed 0 drop 1020 life (KB/Sec) 0/0
   Outbound SPI : 0x       0, transform :
    Socket State: Closed
Session: [0x3121B6F4]
  fvrf: F-VRF,    IPSEC FLOW: permit 47 host 10.74.165.15 host 10.74.164.3
        Outbound: #pkts enc'ed 0 drop 1009 life (KB/Sec) 0/0
Pending DMVPN Sessions:
RT_BMCI_#sh ip nhrp
10.74.160.2/32 via 10.74.160.2
   Tunnel100 created 01:49:19, never expire
   Type: static, Flags: used
   NBMA address: 10.74.164.2
10.74.160.3/32 via 10.74.160.3
   NBMA address: 10.74.164.3
please can anybody help me
and thank you all
