Warning message
Joseph W. Doherty Tue, 02/18/2014 - 07:19
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
"It depends".  Usually yes, if there's no conflict with other AS numbers.
Ray Herbst Tue, 02/18/2014 - 11:13
So if you use the same as for to MPLS clouds would you use prepen to manipulate routes or maybe hsrp???
Jon Marshall Tue, 02/18/2014 - 11:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ray
Can't really answer that without knowing quite a bit more about your topology ie.
are you terminating both providers on the same router or separate routers
what sits behind the routers in each site eg. L3 switches for inter vlan routing or L2 switches using the MPLS routers as their default gateway on the LAN interfaces etc.
do you want to influence outbound traffic or return traffic or both ?
etc.
Jon
Related Content
