Cisco Prime LMS 4.2.2 SystemComplianceCmdCollection job
dfaught
There is an expired evaluation license for the "PI-CM" feature in LMS.  How do I stop the SystemComplianceCmdCollection job from running since it never runs properly without the license?
AFROJ AHMAD
Hi ,
Can you try the below steps:
1) Open a command prompt and go to C:\Progra~1\CSCOpx\bin
2) Issue the command:
cwjava -cw C:\Progra~1\CSCOpx com.cisco.nm.cmf.jrm.jobcli
3) It will take you to the Job CLI mode. Now give the command:
delete   and type the number of the job you want to delete.
for you it is :: delete 6690
It should look something like this: cwjava -cw C:\Progra~1\CSCOpx com.cisco.nm.cmf.jrm.jobcli Established connection with JRM Enter "exit" to quit the CLI delete 1112 Job 1112 deleted. exit
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi ,
Thanks-
Afroz
Thank you!  Yes, that works.  I adjusted it for the Soft Appliance Linux commands like this:
[system1/root-ade ~]# cd /opt/CSCOpx/bin
[system1/root-ade bin]# cwjava -cw /opt/CSCOpx com.cisco.nm.cmf.jrm.jobcli
delete 6690
Job 6690 deleted.
exit
Dave Faught
