Warning message
simple VPN connection problem
Feb 17th, 2014
Hello, I am sure this is something very simple.
I am connecting a 2621 router with an 867 router via an IPSEC VPN connection. Diagram attached.
n.b. the 867 router has a Dialer interface set up but I am not using this for this VPN test, rather I am trying to VPN between the
867 router's FastEthernet0 interface and the 2621 router's FA0/0 interface.
After config, when I run 'show crypto isakmp sa' I get nothing.
Perhaps I have my VPN interface configured incorrectly on the 867 router (due to this ADSL router using layer 2 SVI ports rather than normal router layer 3 ports). Perhaps VPNs can only connect between layer 3 ports rather than 'swouter' ports?
I have set up corresponding access lists on each router to route VPN between networks 192.168.5.0 on the 2621 router and 192.168.250.0 on the 867 router.
I have not actually set up hosts on those networks to test pings. Is it correct that "show crypro isakmp sa" command should show a connection regardless of my inside networks being up or not ?
Thanks for any help.
2621 router config:
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 0
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
no ftp-server write-enable
crypto isakmp policy 10
authentication pre-share
crypto isakmp key vpnkey address 192.168.200.1
no crypto isakmp ccm
crypto ipsec transform-set vpnset esp-aes esp-sha-hmac
crypto map vpnset 10 ipsec-isakmp
set peer 192.168.200.1
set transform-set vpnset
match address 100
interface FastEthernet0/0
ip address 192.168.200.2 255.255.255.0
duplex auto
speed auto
crypto map vpnset
interface FastEthernet0/1
ip address 192.168.5.1 255.255.255.0
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.200.1
no ip http server
no ip http secure-server
access-list 100 permit ip 192.168.5.0 0.0.0.255 192.168.250.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
end
867 router config:
! Last configuration change at 22:06:27 UTC Tue Feb 18 2014
version 15.1
no service pad
hostname phils867
boot-start-marker
boot-end-marker
enable secret 5 $1$i4Bt$U.6aPSrsmLMrgwV6LixLE.
no aaa new-model
wan mode dsl
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip name-server 202.180.64.10
controller VDSL 0
crypto isakmp key vpnkey address 192.168.200.2
set peer 192.168.200.2
match address 100
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description DSL
pvc 0/100
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
shutdown
switchport access vlan 200
no ip address
crypto map vpnset
spanning-tree portfast
interface FastEthernet1
switchport access vlan 250
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan200
description Wired
ip address 192.168.200.1 255.255.255.0
ip virtual-reassembly in
interface Vlan250
ip address 192.168.250.1 255.255.255.0
interface Dialer0
ip address negotiated
no ip redirects
ip mtu 1480
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username xxxxxx password 0 xxxxx
ppp ipcp dns request
ip forward-protocol nd
no ip http server
ip nat inside source list 101 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 192.168.200.2
access-list 100 permit ip 192.168.250.0 0.0.0.255 192.168.5.0 0.0.0.255
dialer-list 1 protocol ip permit
line con 0
exec-timeout 0 0
password phil
logging synchronous
login
no modem enable
terminal-type mon
length 20
line aux 0
line vty 0 4
exec-timeout 0 0
password phil
logging synchronous
login
transport input all
scheduler allocate 60000 1000
end
Marius Gunnerud Tue, 02/18/2014 - 03:43
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Firewalling
The first thing that stands out is that your crypto ACL on the 867 router is incorrect
access-list 100 permit ip host 192.168.250.0 host 192.168.5.0
This should read like this:
Remember that the crypto ACLs must be a mirror image of eachother.
The show crypto isakmp sa command only shows output when there is an active tunnel that is up.  so you would need to send traffic accross the tunnel for the vpn tunnel to be built.  only then will you see something in that output.
Please remember to rate and select a correct answer
fran19422 Tue, 02/18/2014 - 14:53
Hello, thanks for the help.
On the 867 config, I rectified the ACL and edited my original post with the updated config. I also set up hosts on each side's internal network with continous pings. I have an imrpovement but still problems.
Now when I ping from host 192.168.250.2 to 192.168.5.2, I get the message on the 2621 router "
%CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC p
acket.
        (ip) vrf/dest_addr= /192.168.5.1, src_addr= 192.168.250.2, prot= 1
So I thought mabe this might be because regular IP traffic was getting through to the other router before it was encapsulated. So I built an access list to only allow VPN traffic into the 2621 router and block everything else. This prevented the error message above, but the pings are still not working.
access-list 110 permit udp any any eq isakmp
access-list 110 permit udp any any eq non500-isakmp
access-list 110 permit esp any any
access-list 110 permit ahp any any
access-list 110 deny   ip any any
Perhaps this problem might have something to do with which interface I apply the crypto map to on the 867 router due to my use of SVI's on this 'swouter'. Should I apply it to the VLAN interface or the VLAN's subsidiary layer 2 switchport interface ?
Thanks kindly for any ideas.
Marius Gunnerud Wed, 02/19/2014 - 01:06
    2017 Firewalling
I think the crypto map needs to be on the VLAN interface.  The error "packet not an IPsec packet" typically comes when either there is an ACL mismatch or one of the sides is not configured with a crypto map.  Move the crypto map to the VLAN interface and test.
