Ironport M670 no operating system installed
Answered Question
Feb 18th, 2014
Hi! I received an Ironport M670 from RMA but it doesn't have anything installed. It just boot.
I want to know where to find an iso file so i can install manually the Ironport application.
Thanks!
Correct Answer by Robert Sherwin about 3 years 5 months ago
If the RMA appliance does not have anything installed, and you are not getting the standard boot to AsyncOS, you will need to follow-up with the case that was opened for the RMA, or you will need open a new support case:
https://tools.cisco.com/ServiceRequestTool/scm/mgmt/case
You can follow the quick-start guide:
Cisco IronPort M670 Quickstart Guide
Upon boot - you should just be following the standard turn up process.  Once the appliance is online, assign a temporary IP address, and migrate the old configuration as needed, if applicable.
Hope this helps!
-Robert
(*If you have received the answer to your original question, and found this helpful/correct - please mark the question as answered, and be sure to leave a rating to reflect!)
Overall Rating: 5 (1 ratings)
Correct Answer
Robert Sherwin Mon, 03/10/2014 - 07:17
  • Cisco Employee,
Hope this helps!
-Robert
