Warning message
Intercluster dial peer
Answered Question
Feb 18th, 2014
Dear All,
I have a scenario in Lab where I have configured two clusters. Please see the below scenario.
All the phones in 1XX are registered to CUCM and 2XXX are registered to CME and can call to each other in the same cluster.
Now I want to make calls from 1XXX to 2XXX, so what will be dial peer I need to configure in the routers.
Amarjit Das
Correct Answer by Aman Soi about 3 years 6 months ago
Hi Das,
can u try adding session protocol sipv2 in CME router under
dial-peer voice 10 voip
destination-pattern 1...
voice-class codec 1
session target ipv4:172.16.0.1
regds,
aman
Correct Answer by Carlo Poggiarelli about 3 years 6 months ago
Hi Amarjit.
You are missing some details on your configs.
On GW
voice service voip
allow connections sip-to-sip
dial-peer 11
+++you have+++
session target ipv4:10.113.113.2
+++ based on your diagram CUCM IP address should be 10.0.0.1 and session target should point to it+++
session target ipv4:10.0.0.1
In your voice class codec you have selected g729 codec only.
Which codec have you defined on Region configuration on CUCM?
This should match the same codec
Pease check the region associated to device pool defined for the GW.
to simplify this operation allow codec g711ulaw on both CME and GW because is the default codec negotiated by default region on CUCM.
To achieve this, modify voice class codec on both GW and CME:
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
++++ON CME+++
Remove dialpeer 11( you don't need it because extensions are locally registered)
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Overall Rating: 5 (4 ratings)
Suresh Subramanian Wed, 02/19/2014 - 00:11
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, October 2015
Hello Amarjit,
In CUCM, you can configure a SIP Trunk with CME as destination IP. configure RP with 2XXX and assign the SIP trunk to it.
in CME, configure voip dial-peer to receive the call from CUCM.
and configure another dial-peer with dest-pattern: 1... and session target
Ensure you have proper IP routing between these devices and confirm the reachability.
config example below
voice service voip
    sip
      bind control source-interface <.2 interface>
      bind media source-interface <.2 interface>
description **SIP TRUNK from CUCM**
incoming called-number 2...
dtmf-relay rtp-nte
no vad
dial-peer voice 11 voip
description **SIP TRUNK to CUCM**
dtmf-relay rtp-nte
no vad
//Suresh
Please rate all the useful posts.
Carlo Poggiarelli Wed, 02/19/2014 - 00:20
  • Green, 3000 points or more
Hi Amarjit.
First I would suggest you to change signaling protocol between CUCM cluster and the Voice gateway from H323 to Sip.
In your scenario coul be enough a route pattern in CUCM such as 2XXX pointing to the gateway.
Than on H323 Gateway:
voice class codec 1
codec preference 1 g711alaw
codec preference 1 g728br8
description ++++TO CME++++
destination-pattern 2...
session target ipv4:192.168.0.2
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
description ++++TO CUCM++++
voice-class codec 1
no vad
dial-peer voice 12 voip
description ++++Incoming From CME++++
incoming called-number 1...
voice-class codec 1
no vad
In the same way on CME configure dialpeers pointing back to H323 Gateway.
Carlo
amarjit4321 Wed, 02/19/2014 - 00:49
Hi Carlo,
Thanks for your reply.
I will try the same you have said.
But can you tell me what is configuration required to configure the gateway as SIP.
Amarjit Das
Suresh Subramanian Wed, 02/19/2014 - 00:54
Here is the config to enable to SIP on the GW:
voice service voip
    sip
      bind control source-interface < interface>
//Suresh
amarjit4321 Wed, 02/19/2014 - 01:15
Thank Suresh,
Let me try with the said configuration.
Vil let u know..
Amarjit Das
Carlo Poggiarelli Wed, 02/19/2014 - 01:17
Hi Amarjit.
In addition to what Suresh mentioned (+5) you should configure a sip trunk on CUCM specifing the ip address of the gateway and modify dialpeers on both Gateway and CME specifyng sip as session protocol.
Eg.
voice-class codec 1
dtmf-relay rtp-nte
no vad
session protoco sipv2
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
Remember also to allow sip to sip transactions by configuring
voice service voip
..and last from IOS version 15.1(2) toll fraud prevetion was introduced by default and asks you to specify ip address allowed to initiate a SIP or H323 session with your VG.
You can configure it through:
voice service voip
ip address trusted list
ipv4 x.x.x.x y.y.y.y where x.x.x.x is the subnet or the host you want to allow and y.y.y.y is the subnet mask.
To disable this feature:
voice service voip
no ip address trusted list
Carlo
Aman Soi Wed, 02/19/2014 - 01:26
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Hi Amarjit,
[+5] for Carlo for inputs.
can u share the config on CME&  Gateway?
regds,
aman
amarjit4321 Wed, 02/19/2014 - 02:54
I have configured both the routers as said above but still call is not established.
Please find the configuration below ---
VOICE-GW
version 12.4
hostname VOICE-GW
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice service voip
sip
  session transport tcp
voice class codec 1
codec preference 1 g729br8
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.113.113.4 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
ip address 172.16.0.1 255.255.255.252
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip http server
no ip http secure-server
control-plane
voice-class codec 1
session target ipv4:172.16.0.2
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
CME
version 12.4
hostname CME
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip domain name lab.local
voice class codec 1
archive
log config
  hidekeys
ip address 172.16.0.2 255.255.255.252
duplex auto
speed auto
ip address 192.168.0.2 255.255.255.0
duplex auto
speed auto
no ip http server
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
control-plane
voice-class codec 1
voice-class codec 1
voice-class codec 1
no vad
telephony-service
max-ephones 2
max-dn 2
ip source-address 192.168.0.2 port 2000
auto assign 1 to 2
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
number 2001
ephone-dn  2
number 2002
ephone  1
no multicast-moh
mac-address 001F.CA4C.6E03
keepalive 30 auxiliary 0
type 7941
button  1:1
ephone  2
no multicast-moh
Please suggest.
Amarjit Das
Correct Answer
Carlo Poggiarelli Wed, 02/19/2014 - 03:18
Hi Amarjit.
On GW
voice service voip
dial-peer 11
+++you have+++
voice class codec 1
++++ON CME+++
Carlo
amarjit4321 Wed, 02/19/2014 - 03:58
Hi Carlo,
Thank for your reply,
Now I can call from 1XXX to 2XXX, but from 2XXX to 1XXX call is not happening.
Please suggest.
Carlo Poggiarelli Wed, 02/19/2014 - 04:05
Hi Amarjit.
Did you check incoming CSS on configured sip trunk on CUCM?
Please send the actual config of both CME and Gateway.
Please activate a debug voip dialpeer inout on both, make a call and send the output.
Carlo
amarjit4321 Wed, 02/19/2014 - 04:25
Hi Carlo,
I have kept default device pool and CSS.
Please find the config below --
Voice Gateway --
voice service voip
allow-connections sip to sip
sip
voice class codec 1
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
CME Router
voice class codec 1
duplex auto
speed auto
duplex auto
speed auto
no ip http server
voice-class codec 1
voice-class codec 1
no vad
telephony-service
max-ephones 2
max-dn 2
auto assign 1 to 2
ephone-dn  1
number 2001
ephone-dn  2
number 2002
ephone  1
no multicast-moh
type 7941
button  1:1
ephone  2
no multicast-moh
Note : Please dont worry about the IP address as I have made some changes in the IP's
Now when I am calling from 1001 to 2001 call is establishing, but when I am calling from 2001 to 1001 call is not establishing.
So I have collected the logs after calling from 2001 to 1001 on both the routers.
Voice Gateway debug log --
*Mar  1 02:40:45.371: //-1/2B88C4988041/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2001, Called Number=1001, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  1 02:40:45.379: //-1/2B88C4988041/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=12
*Mar  1 02:40:45.395: //-1/2B88C4988041/DPM/dpAssociateIncomingPeerCore:
*Mar  1 02:40:45.399: //-1/2B88C4988041/DPM/dpAssociateIncomingPeerCore:
*Mar  1 02:40:45.459: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=1001, Called Number=1001, Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  1 02:40:45.463: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=1001
*Mar  1 02:40:45.467: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
*Mar  1 02:40:45.471: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=11
*Mar  1 02:40:45.475: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1001, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=11
*Mar  1 02:40:45.483: //-1/2B88C4988041/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1001, Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  1 02:40:45.483: //-1/2B88C4988041/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
CME Router Debug Logs--
*Mar  1 01:47:49.155: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2001, Called Number=, Voice-Interface=0x65ECD080,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
*Mar  1 01:47:49.159: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20001
*Mar  1 01:47:49.675: //-1/2B88C4988041/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1, Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  1 01:47:49.679: //-1/2B88C4988041/DPM/dpMatchPeersCore:
CME#
   Result=Partial Matches(1) after DP_MATCH_DEST
*Mar  1 01:47:49.683: //-1/2B88C4988041/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
*Mar  1 01:47:49.867: //-1/2B88C4988041/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=10, Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  1 01:47:49.871: //-1/2B88C4988041/DPM/dpMatchPeersCore:
*Mar  1 01:47:49.871: //-1/2B88C4988041/DPM/dpMatchPeersMoreArg:
*Mar  1 01:47:50.067: //-1/2B88C4988041/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=100, Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  1 01:47:50.071: //-1/2B88C4988041/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.071: //-1/2B88C4988041/DPM/dpMatchPeersMoreArg:
*Mar  1 01:47:50.267: //-1/2B88C4988041/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.271: //-1/2B88C4988041/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.271: //-1/2B88C4988041/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 01:47:50.283: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.287: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.287: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 01:47:50.299: //-1/2B88C4988041/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.303: //-1/2B88C4988041/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.303: //-1/2B88C4988041/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Please suggest.
Amarjit Das
Suresh Subramanian Wed, 02/19/2014 - 05:04
from the CME router & the H323 GW, pelase capture 'debug voip ccapi inout' for a test call and let us know the calling/called numbers
//Suresh
Carlo Poggiarelli Wed, 02/19/2014 - 05:09
Hi Amarjit.
Did you configure any partition for CUCM extensions?
Let me know
Carlo
amarjit4321 Wed, 02/19/2014 - 05:21
No, I have not configured any partitions.
Amarjit Das
amarjit4321 Wed, 02/19/2014 - 05:31
Please find the latest debug details below --
Voice Gateway --
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
VOICE-GW#
VOICE-GW#
VOICE-GW#
VOICE-GW#
*Mar  1 02:40:53.087: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/1 (not full duplex), with CME.lab.local FastEthernet0/0 (full duplex).
VOICE-GW#u all
All possible debugging has been turned off
VOICE-GW#=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.02.19 18:45:08 =~=~=~=~=~=~=~=~=~=~=~=
*Mar  1 03:40:43.635: //-1/8C4612CA8069/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:40:43.639: //-1/8C4612CA8069/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:40:43.655: //-1/8C4612CA8069/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:40:43.663: //-1/8C4612CA8069/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:40:43.699: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 03:40:43.703: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 03:40:43.707: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 03:40:43.707: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
*Mar  1 03:40:43.711: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:40:43.727: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 03:40:43.731: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 03:40:43.735: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 03:40:43.735: //-1/8C4612CA8069/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
CME Router --
CME#
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 01:47:50.487: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/0 (not half duplex), with VOICE-GW FastEthernet0/1 (half duplex).
CME#
CME#u all
CME#
CME#=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.02.19 18:44:56 =~=~=~=~=~=~=~=~=~=~=~=
*Mar  1 02:47:47.431: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Mar  1 02:47:47.435: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Mar  1 02:47:47.951: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
CME#
*Mar  1 02:47:47.955: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:47.955: //-1/8C4612CA8069/DPM/dpMatchPeersMoreArg:
*Mar  1 02:47:48.143: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.147: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.147: //-1/8C4612CA8069/DPM/dpMatchPeersMoreArg:
*Mar  1 02:47:48.343: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.347: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.347: //-1/8C4612CA8069/DPM/dpMatchPeersMoreArg:
*Mar  1 02:47:48.543: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.547: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.551: //-1/8C4612CA8069/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 02:47:48.563: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.567: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 02:47:48.575: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.579: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.583: //-1/8C4612CA8069/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Calling number -- 2001
Called Number -- 1001
Amarjit Das
Suresh Subramanian Wed, 02/19/2014 - 05:38
you have posted the output of 'debug voip dialpeer' not 'debug voip ccapi inout'. Could you please capture 'debug voip ccapi inout'?
//Suresh
amarjit4321 Wed, 02/19/2014 - 05:51
Hi Suresh,
Please find the debug details below --
Voice Gateway --
*Mar  1 04:11:53.186: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/1 (not full duplex), with CME.lab.local FastEthernet0/0 (full duplex).
VOICE-GW#
VOICE-GW#
*Mar  1 04:12:05.346: //-1/EC2BC7B38080/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=172.16.0.2
   ----- ccCallInfo IE subfields -----
   cisco-ani=2001
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=1001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Mar  1 04:12:05.362: //-1/EC2BC7B38080/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x671BACAC, Call Info(
   Calling Number=2001,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1001(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=37
*Mar  1 04:12:05.362: //-1/EC2BC7B38080/CCAPI/ccCheckClipClir:
   In: Calling Number=2001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=2001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Mar  1 04:12:05.366: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar  1 04:12:05.366: :cc_get_feature_vsa malloc success
*Mar  1 04:12:05.366:  cc_get_feature_vsa count is 1
*Mar  1 04:12:05.370: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar  1 04:12:05.370: :FEATURE_VSA attributes are: feature_name:0,feature_time:1712564096,feature_id:37
*Mar  1 04:12:05.370: //37/EC2BC7B38080/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1001(TON=Unknown, NPI=Unknown))
*Mar  1 04:12:05.382: //37/EC2BC7B38080/CCAPI/cc_process_call_setup_ind:
   Event=0x66149678
*Mar  1 04:12:05.402: //37/EC2BC7B38080/CCAPI/ccCallSetContext:
   Context=0x676E6268
*Mar  1 04:12:05.402: //37/EC2BC7B38080/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 37 with tag 10 to app "_ManagedAppProcess_Default"
*Mar  1 04:12:05.414: //37/EC2BC7B38080/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
*Mar  1 04:12:05.434: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Mar  1 04:12:05.438: : updating existing feature vsa
*Mar  1 04:12:05.438: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Mar  1 04:12:05.442:  feature call basic
*Mar  1 04:12:05.446: //37/EC2BC7B38080/CCAPI/ccCallDisconnect:
   Cause Value=3, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=3, Call Entry(Responsed=TRUE, Cause Value=3)
*Mar  1 04:12:05.450: //37/EC2BC7B38080/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Mar  1 04:12:05.462: //37/EC2BC7B38080/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x671BACAC, Tag=0x0, Call Id=37,
   Call Entry(Disconnect Cause=3, Voice Class Cause Code=0, Retry Count=0)
*Mar  1 04:12:05.470: //37/EC2BC7B38080/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
*Mar  1 04:12:05.474: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar  1 04:12:05.474: :cc_free_feature_vsa freeing 6613A778
*Mar  1 04:12:05.478: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar  1 04:12:05.478:  vsacount in free is 0
CME Router  --
*Mar  1 03:18:50.479: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/0 (not half duplex), with VOICE-GW FastEthernet0/1 (half duplex).
CME#
*Mar  1 03:19:06.307: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:19:06.311: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:19:06.323: //-1/EC2BC7B38080/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=2001
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
*Mar  1 03:19:06.339: //-1/EC2BC7B38080/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x65ECD080, Call Info(
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20001, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Mar  1 03:19:06.343: //-1/EC2BC7B38080/CCAPI/ccCheckClipClir:
*Mar  1 03:19:06.347: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar  1 03:19:06.347: :cc_get_feature_vsa malloc success
*Mar  1 03:19:06.347:  cc_get_feature_vsa count is 1
*Mar  1 03:19:06.351: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar  1 03:19:06.351: :FEATURE_VSA attributes are: feature_name:0,feature_time:1719764832,feature_id:53
*Mar  1 03:19:06.351: //53/EC2BC7B38080/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=(TON=Unknown, NPI=Unknown))
*Mar  1 03:19:06.363: //53/EC2BC7B38080/CCAPI/cc_process_call_setup_ind:
   Event=0x66826990
*Mar  1 03:19:06.375: //53/EC2BC7B38080/CCAPI/ccCallSetContext:
   Context=0x66C81A50
*Mar  1 03:19:06.379: //53/EC2BC7B38080/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 53 with tag 20001 to app "_ManagedAppProcess_Default"
*Mar  1 03:19:06.403: //53/EC2BC7B38080/CCAPI/ccCallSetupAck:
   Call Id=53
*Mar  1 03:19:06.403: //53/EC2BC7B38080/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
*Mar  1 03:19:06.407: //53/EC2BC7B38080/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=53
*Mar  1 03:19:06.411: //53/EC2BC7B38080/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
*Mar  1 03:19:06.415: //53/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x35, digit_event=0x1, enable=TRUE, consume=FALSE)
*Mar  1 03:19:06.415: //53/EC2BC7B38080/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=53
*Mar  1 03:19:06.419: //53/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x65ECD080, callID=0x35, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*Mar  1 03:19:06.419: //53/EC2BC7B38080/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x65ECD080, Call Id=53
*Mar  1 03:19:06.423: //53/EC2BC7B38080/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
*Mar  1 03:19:07.415: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=53, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x202A60, Rtp Expiration=0x0
*Mar  1 03:19:07.419: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_end:
   Source Call Id=53, Digit=1, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
*Mar  1 03:19:07.423: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_end:
   Call Entry(Handoff Depth=0)
*Mar  1 03:19:07.435: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:07.439: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:07.439: //-1/EC2BC7B38080/DPM/dpMatchPeersMoreArg:
*Mar  1 03:19:08.763: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_begin:
   Source Call Id=53, Digit=0, DigitBeginFlags=0x0,
   Rtp Timestamp=0x20A760, Rtp Expiration=0x0
*Mar  1 03:19:08.767: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_end:
   Source Call Id=53, Digit=0, Duration=100,
*Mar  1 03:19:08.775: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:08.779: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:08.779: //-1/EC2BC7B38080/DPM/dpMatchPeersMoreArg:
*Mar  1 03:19:08.919: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x212460, Rtp Expiration=0x0
*Mar  1 03:19:08.923: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_end:
*Mar  1 03:19:08.931: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:08.935: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:08.935: //-1/EC2BC7B38080/DPM/dpMatchPeersMoreArg:
*Mar  1 03:19:10.211: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x21A160, Rtp Expiration=0x0
*Mar  1 03:19:10.215: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_end:
*Mar  1 03:19:10.219: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_end:
*Mar  1 03:19:10.223: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:10.227: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:10.227: //-1/EC2BC7B38080/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 03:19:10.231: //53/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x35, digit_event=0x0, enable=FALSE, consume=FALSE)
*Mar  1 03:19:10.231: //53/EC2BC7B38080/CCAPI/ccCallReportDigits:
*Mar  1 03:19:10.235: //53/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x65ECD080, callID=0x35, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
*Mar  1 03:19:10.239: //53/EC2BC7B38080/CCAPI/cc_api_call_report_digits_done:
*Mar  1 03:19:10.251: //53/EC2BC7B38080/CCAPI/ccCallProceeding:
*Mar  1 03:19:10.251: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 03:19:10.255: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 03:19:10.259: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 03:19:10.267: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:10.271: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:10.271: //-1/EC2BC7B38080/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 03:19:10.279: //53/EC2BC7B38080/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=10, Params=0x66C82918, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Mar  1 03:19:10.279: //53/EC2BC7B38080/CCAPI/ccCheckClipClir:
*Mar  1 03:19:10.283: //53/EC2BC7B38080/CCAPI/ccCheckClipClir:
*Mar  1 03:19:10.283: //53/EC2BC7B38080/CCAPI/ccCallSetupRequest:
   Destination Pattern=1..., Called Number=1001, Digit Strip=FALSE
*Mar  1 03:19:10.287: //53/EC2BC7B38080/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=FALSE,
   Guid=EC2BC7B3-2BF9-11D6-8080-9E453EAF7E4F, Outgoing Dial-peer=10
*Mar  1 03:19:10.287: //53/EC2BC7B38080/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=2001
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=1001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Mar  1 03:19:10.295: //53/EC2BC7B38080/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x66043D40, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=2001,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1001(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=10, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Mar  1 03:19:10.299: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar  1 03:19:10.299: :cc_get_feature_vsa malloc success
*Mar  1 03:19:10.299:  cc_get_feature_vsa count is 2
*Mar  1 03:19:10.299: :FEATURE_VSA attributes are: feature_name:0,feature_time:1719765048,feature_id:54
*Mar  1 03:19:10.303: //54/EC2BC7B38080/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Mar  1 03:19:10.303: //54/EC2BC7B38080/CCAPI/ccCallSetContext:
   Context=0x66C828C8
*Mar  1 03:19:10.307: //53/EC2BC7B38080/CCAPI/ccSaveDialpeerTag:
*Mar  1 03:19:10.643: //54/EC2BC7B38080/CCAPI/cc_api_call_disconnected:
   Cause Value=3, Interface=0x66043D40, Call Id=54
   Call Entry(Responsed=TRUE, Cause Value=3, Retry Count=0)
*Mar  1 03:19:10.647: //53/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*Mar  1 03:19:10.651: //54/EC2BC7B38080/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=54
*Mar  1 03:19:10.651: //54/EC2BC7B38080/CCAPI/ccCallDisconnect:
   Cause Value=3, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=3)
*Mar  1 03:19:10.655: //54/EC2BC7B38080/CCAPI/ccCallDisconnect:
*Mar  1 03:19:10.655: //54/EC2BC7B38080/CCAPI/cc_api_get_transfer_info:
*Mar  1 03:19:10.675: //54/EC2BC7B38080/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x66043D40, Tag=0x0, Call Id=54,
*Mar  1 03:19:10.679: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar  1 03:19:10.679: :cc_free_feature_vsa freeing 66818830
*Mar  1 03:19:10.679:  vsacount in free is 1
*Mar  1 03:19:10.695: //53/EC2BC7B38080/CCAPI/ccCallDisconnect:
*Mar  1 03:19:10.699: //53/EC2BC7B38080/CCAPI/cc_api_get_transfer_info:
*Mar  1 03:19:17.307: //53/EC2BC7B38080/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x65ECD080, Tag=0x0, Call Id=53,
*Mar  1 03:19:17.311: //53/EC2BC7B38080/CCAPI/cc_api_call_disconnect_done:
*Mar  1 03:19:17.315: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar  1 03:19:17.315: :cc_free_feature_vsa freeing 66818758
Amarjit Das
Correct Answer
Aman Soi Wed, 02/19/2014 - 06:12
    2017 IP Telephony
Hi Das,
voice-class codec 1
regds,
aman
amarjit4321 Wed, 02/19/2014 - 06:23
Hi Mr.Aman,
Yes, after adding the said command it works fine.
Now I can call both way.
Thanks for your support.
Amarjit Das
