ASA 5520 - port-channel
Feb 19th, 2014
I want a 2G fiber downlink on my ASA 5520. It has a 4GE-SSM module installed.
The problem is: it works OK on 8.47 IOS, but on 9.03 all interfaces of 4GE refused to become a channel-gropu members.
Encryption hardware device : Cisco ASA-55xx on-board accelerator (revision 0x0)
Boot microcode        : CN1000-MC-BOOT-2.00
SSL/IKE microcode     : CNLite-MC-SSLm-PLUS-2.03
IPSec microcode       : CNlite-MC-IPSECm-MAIN-2.08
Cisco Adaptive Security Appliance Software Version 9.0(3)
Reading from flash...
channel-group 1 mode on
ERROR: % Invalid input detected at '^' marker.
*** Output from config line 50, " channel-group 1 mode on"
*** Output from config line 57, " channel-group 1 mode on"
asa# show run int po1
interface Port-channel1
description Intranet
nameif INSIDE
security-level 100
ip address 10.149.8.252 255.255.255.0
asa# show run int g1/2
interface GigabitEthernet1/2
media-type sfp
no nameif
no security-level
no ip address
asa# conf t
asa(config)# int g1/2
asa(config-if)# chan?
ERROR: % Unrecognized command
asa(config)# int g0/0
asa(config-if)# c?
interface mode commands/options:
channel-group
In documentation, I found:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa84/configuration/guide/asa_84_cli_config/interface_start.html
...You cannot use interfaces on the 4GE SSM, including the integrated 4GE SSM in slot 1 on the ASA 5550, as part of an EtherChannel...
WTF??
Related Content
