02-19-2014 09:49 AM - edited 03-10-2019 09:25 PM
We have a Nexus 1110-S HA pair. RADIUS authentication works fine, till we have a failover (initiated by power off or system switchover).
The failover works fine but RADIUS authentication is no longer possible.
debug radius aaa-request logs:
ee-nexus1# 2014 Feb 19 18:19:28.561755 radius: get_radius_server_info_from_group:
2014 Feb 19 18:19:28.562018 radius: is_intf_up_with_valid_ip(1305):Can't determine interface mgmt0 status(up/down).
2014 Feb 19 18:19:28.562248 radius: radius_update_request_state_for_server(1373):No if_index configured for group mgmt0 or no_ip assigned
2014 Feb 19 18:19:28.562484 radius: radius_update_request_state_for_server(1375):Trying to retrieve intf info frm other groups to which this server belogns to..
2014 Feb 19 18:19:28.562722 radius: is_intf_up_with_valid_ip(1305):Can't determine interface mgmt0 status(up/down).
2014 Feb 19 18:19:28.562948 radius: radius_update_request_state_for_server(1399):Trying global...
2014 Feb 19 18:19:28.563180 radius: radius_update_request_state_for_server(1410):global interface will be used
2014 Feb 19 18:19:28.563406 radius: radius_update_request_state_for_server(1421):global intf is not configured or up with valid ip.
2014 Feb 19 18:19:28.563650 radius: radius_update_request_state_for_server(1433):Using if_index
2014 Feb 19 18:19:28.563944 radius: getaddrinfo serv_port 1645
2014 Feb 19 18:19:29.567825 radius: radius_set_src_intf(1707):setsockopt success, using src-intf:for server: 152.88.114.12 for sock: 22 Error returned:0x0 errno string:Invalid argument
2014 Feb 19 18:19:34.618054 radius: radius_set_src_intf(1707):setsockopt success, using src-intf:for server: 152.88.114.12 for sock: 22 Error returned:0x0 errno string:No route to host
2014 Feb 19 18:19:39.668358 radius: radius_request_process: RADIUS server 152.88.114.12 failed to respond evenafter all retries
2014 Feb 19 18:19:39.668841 radius: radius_request_process_next_server: All RADIUS servers failed to respond after retries.
ping to 152.88.114.12 works fine.
Configuration:
version 4.2(1)SP1(6.2)
feature telnet
username admin password 5 * role network-admin
username orion password 5 * role network-operator
banner motd #Cisco VSA#
ssh key rsa 2048
ip domain-lookup
ip domain-lookup
radius-server host 152.88.114.12 key 7 * auth-port 1645 acct-port 1646 authentication accounting
aaa group server radius AD-authentication
source-interface mgmt0
hostname ee-nexus1
snmp-server user admin network-admin auth md5 * priv * localize
dkey
snmp-server user orion network-operator auth sha * priv * localizedkey
snmp-server user orion oriongroup
ntp server 172.17.72.1
aaa authentication login default group AD-authentication
vrf context management
ip route 0.0.0.0/0 172.17.72.1
vlan 1,372-373
port-channel load-balance ethernet source-mac
port-profile default max-ports 32
vdc ee-nexus1 id 1
limit-resource vlan minimum 16 maximum 2049
limit-resource monitor-session minimum 0 maximum 2
limit-resource vrf minimum 16 maximum 8192
limit-resource port-channel minimum 0 maximum 768
limit-resource u4route-mem minimum 32 maximum 32
limit-resource u6route-mem minimum 16 maximum 16
limit-resource m4route-mem minimum 58 maximum 58
limit-resource m6route-mem minimum 8 maximum 8
network-uplink type 1
interface GigabitEthernet1
interface GigabitEthernet2
interface GigabitEthernet3
interface GigabitEthernet4
interface GigabitEthernet5
interface GigabitEthernet6
interface PortChannel1
virtual-service-blade VSM1
virtual-service-blade-type name VSM-1.3
interface control vlan 373
interface packet vlan 373
ramsize 3072
disksize 3
numcpu 1
cookie 1669967837
no shutdown
interface VsbEthernet1/1
interface VsbEthernet1/2
interface VsbEthernet1/3
interface mgmt0
ip address 172.17.72.10/24
interface control0
clock timezone MET 1 0
clock summer-time MEST 5 sunday march 02:00 5 sunday October 03:00 60
line console
boot kickstart bootflash:/nexus-1010-kickstart-mz.4.2.1.SP1.6.2.bin
boot system bootflash:/nexus-1010-mz.4.2.1.SP1.6.2.bin
svs-domain
domain id 1
control vlan 373
management vlan 372
svs mode L2
logging server 152.88.6.10
debug radius aaa-request-lowlevel logs:
ee-nexus1# 2014 Feb 19 18:36:37.617895 radius: fsrv_sdb_process_msg: vdc-id[1] mts_opc[8441][MTS_OPC_RADIUS_NEW_AAA_REQ] 0xbfffe590 0xb5cc2c60 375
2014 Feb 19 18:36:37.618235 radius: fsrv didnt consume 8441 opcode
2014 Feb 19 18:36:37.618470 radius: process_aaa_radius_request: calling radius_pap_authenticate with user gutadm,servergroup AD-authentication, hostname
2014 Feb 19 18:36:37.618711 radius: radius_pap_authenticate: received PAP authentication request for xxxxxx
2014 Feb 19 18:36:37.618961 radius: get_radius_server_group_info: entering...
2014 Feb 19 18:36:37.619238 radius: RADIUS_FREE 0x8197264: radius_server_group_info_free
2014 Feb 19 18:36:37.619524 radius: build_radius_packet: entering for user xxxxxx
2014 Feb 19 18:36:37.619819 radius: radius_pap_authenticate: built the PAP RADIUS request packet, now send to the servers one by one
2014 Feb 19 18:36:37.620047 radius: radius_request_process: event: FIRST_REQUEST, switch to first server
2014 Feb 19 18:36:37.620268 radius: radius_request_process_next_server:
2014 Feb 19 18:36:37.620489 radius: radius_request_process_next_server: looping thru servers in servergroup...
2014 Feb 19 18:36:37.620722 radius: get_radius_server_info_from_group:
2014 Feb 19 18:36:37.620945 radius: radius_update_request_state_for_server:
2014 Feb 19 18:36:37.621186 radius: is_intf_up_with_valid_ip(1305):Can't determine interface mgmt0 status(up/down).
2014 Feb 19 18:36:37.621414 radius: radius_update_request_state_for_server(1373):No if_index configured for group mgmt0 or no_ip assigned
2014 Feb 19 18:36:37.621653 radius: radius_update_request_state_for_server(1375):Trying to retrieve intf info frm other groups to which this server belogns to..
2014 Feb 19 18:36:37.621890 radius: is_intf_up_with_valid_ip(1305):Can't determine interface mgmt0 status(up/down).
2014 Feb 19 18:36:37.622116 radius: radius_update_request_state_for_server(1399):Trying global...
2014 Feb 19 18:36:37.622347 radius: radius_update_request_state_for_server(1410):global interface will be used
2014 Feb 19 18:36:37.622588 radius: radius_update_request_state_for_server(1421):global intf is not configured or up with valid ip.
2014 Feb 19 18:36:37.622813 radius: radius_update_request_state_for_server(1433):Using if_index
2014 Feb 19 18:36:37.623080 radius: radius_get_ip_local_from_remote(314): Setting context id to 1
2014 Feb 19 18:36:37.623304 radius: radius_get_ip_local_from_remote(319): Getting source IP for host 152.88.114.12.
2014 Feb 19 18:36:37.623611 radius: radius_get_ip_local_from_remote(322): Returning the source IP 0.0.0.0 for host 152.88.114.12.
2014 Feb 19 18:36:37.623842 radius: radius_update_request_state_for_server(1480): Using IP 0.0.0.0 as NAS IP.
2014 Feb 19 18:36:37.624074 radius: radius_update_request_state_for_server(1492): Can not find the source IP for destination IP152.88.114.12 topopulate the NAS IP.
2014 Feb 19 18:36:37.624299 radius: getaddrinfo serv_port 1645
2014 Feb 19 18:36:37.624541 radius: Entering : check_local_cache : Line : 978
2014 Feb 19 18:36:37.624765 radius: serv_id : 152.88.114.12:1645
2014 Feb 19 18:36:37.624991 radius: Entry Found
2014 Feb 19 18:36:37.625211 radius: Entering : get_res_back : Line : 487
2014 Feb 19 18:36:37.625437 radius: No of entries in server_procjob_data_t : 1
2014 Feb 19 18:36:37.625669 radius: Exiting: get_res_back , Line : 564
2014 Feb 19 18:36:37.625897 radius: Found in Local Cache
2014 Feb 19 18:36:37.626124 radius: returning sockfd 22 for host 152.88.114.12:1645
2014 Feb 19 18:36:37.626352 radius: radius_request_process_next_server: found a valid server 152.88.114.12
2014 Feb 19 18:36:37.626589 radius: radius_request_process : Address family AF_INET
2014 Feb 19 18:36:37.626811 radius: radius_request_process(2869): neither local or global source interface configured
2014 Feb 19 18:36:37.627038 radius: radius_request_process(2887): vrf not configured
2014 Feb 19 18:36:37.627258 radius: radius_request_process(2888): Setting context id to 1
2014 Feb 19 18:36:37.627484 radius: sending 58 bytes to 152.88.114.12 port 1645 vrf
2014 Feb 19 18:36:37.633409 radius: radius_set_src_intf(1707):setsockopt success, using src-intf:for server: 152.88.114.12 for sock: 22 Error returned:0x0 errno string:Success
2014 Feb 19 18:36:37.633964 radius: radius_pap_authenticate: exiting
2014 Feb 19 18:36:37.634200 radius: process_aaa_radius_request: returning TRUE...
2014 Feb 19 18:36:42.680059 radius: radius_request_process : Address family AF_INET
2014 Feb 19 18:36:42.680283 radius: radius_request_process(2869): neither local or global source interface configured
2014 Feb 19 18:36:42.680506 radius: radius_request_process(2887): vrf not configured
2014 Feb 19 18:36:42.680727 radius: radius_request_process(2888): Setting context id to 1
2014 Feb 19 18:36:42.680958 radius: sending 58 bytes to 152.88.114.12 port 1645 vrf
2014 Feb 19 18:36:42.681529 radius: radius_set_src_intf(1707):setsockopt success, using src-intf:for server: 152.88.114.12 for sock: 22 Error returned:0x0 errno string:No route to host
2014 Feb 19 18:36:47.730761 radius: radius_request_process: RADIUS server 152.88.114.12 failed to respond evenafter all retries
2014 Feb 19 18:36:47.730994 radius: trying out next server
2014 Feb 19 18:36:47.731230 radius: radius_request_process_next_server:
2014 Feb 19 18:36:47.731452 radius: radius_request_process_next_server: looping thru servers in servergroup...
2014 Feb 19 18:36:47.731896 radius: radius_request_process_next_server: All RADIUS servers failed to respond after retries.
2014 Feb 19 18:36:47.732117 radius: pap_auth_info_unavail_func: entering for aaa session 0
2014 Feb 19 18:36:47.732348 radius: pap_reply: entering for aaa session: 0
2014 Feb 19 18:36:47.732590 radius: send_aaa_radius_resp_mts: entering for aaa session 0
2014 Feb 19 18:36:47.736242 radius: send_aaa_radius_resp_mts: exiting for aaa session 0
2014 Feb 19 18:36:47.736474 radius: pap_reply: exiting for aaa session: 0
2014 Feb 19 18:36:47.736696 radius: pap_auth_info_unavail_func: exiting for aaa session 0
2014 Feb 19 18:36:47.736920 radius: RADIUS_FREE 0x819a8c4: free_radius_state
2014 Feb 19 18:36:47.737145 radius: RADIUS_FREE 0x8194394: free_radius_state
Any idea what's wrong?
Thanks in advance
Thomas
04-14-2014 08:53 AM
I found a solution
in
we should replace source-interface mgmt0 with use-vrf management
