Aironet 1600 and RADIUS EAP-TTLS
Feb 19th, 2014
I'm trying to configure WLAN authorization with RADIUS (EAP-TTLS) on my Cisco Aironet 1600.
At the datasheet (
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1600-series/data_sheet_c78-715702.html) it an information that this model can handle this.
Sadly I can't configure... Coud anybody help mi with that case?
My config is:
Current configuration : 4013 bytes
! Last configuration change at 18:22:15 UTC Wed Feb 19 2014
! NVRAM config last updated at 18:22:15 UTC Wed Feb 19 2014
version 15.2
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$BPWA$C5uySGSrxxkQzUodYDhXq/
aaa new-model
aaa group server radius rad_eap
server 192.168.55.22 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
ip cef
dot11 syslog
dot11 vlan-name TP_VLAN vlan 50
dot11 ssid TEST
   vlan 2
   authentication open eap eap_methods1
   authentication shared eap eap_methods1
   authentication network-eap eap_methods1
   dot1x eap profile eapttls
   mbssid guest-mode
eap profile eapttls
dot1x test timeout 3
username Cisco password 7 01300F175804
bridge irb
interface Dot11Radio0
no ip address
encryption vlan 50 mode ciphers aes-ccm tkip
ssid TEST
antenna gain 0
stbc
beamform ofdm
mbssid
channel 2472
station-role root
interface Dot11Radio0.2
encapsulation dot1Q 2 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.50
encapsulation dot1Q 50
bridge-group 50
bridge-group 50 subscriber-loop-control
bridge-group 50 spanning-disabled
bridge-group 50 block-unknown-source
no bridge-group 50 source-learning
no bridge-group 50 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
ssid TEST
antenna gain 0
no dfs band block
stbc
beamform ofdm
mbssid
channel dfs
station-role root
interface Dot11Radio1.2
bridge-group 1
interface Dot11Radio1.50
bridge-group 50
interface GigabitEthernet0
no ip address
duplex auto
speed auto
interface GigabitEthernet0.2
bridge-group 1
interface GigabitEthernet0.50
bridge-group 50
interface BVI1
ip address 192.168.55.19 255.255.255.0
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip route 0.0.0.0 0.0.0.0 172.20.0.2
ip route 0.0.0.0 0.0.0.0 172.22.0.1
ip radius source-interface BVI1
radius-server local
  no authentication mac
  nas 192.168.55.22 key 7 131112011F5D5679
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.55.22 auth-port 1812 acct-port 1813 key 7 044F0E151B701E1D
radius-server vsa send accounting
bridge 1 route ip
wlccp ap eap profile eapttls
line con 0
line vty 0 4
password 7 072C285F4D06
authorization exec local
transport input all
end
Thank you in advance,
Pawel
eschinzer Tue, 06/02/2015 - 15:35
I am also having this problem with only the Aironet 1600 series APs in our environment.  We're using EAP-TLS and everything looks configured correctly, all clients have the cert installed, but it will not connect to the Aironet 1600s.
Related Content
