Warning message
CVP file propogation
Answered Question
Feb 19th, 2014
      Hi All,
Does anyone know is there any possibility to propagate media files between multiple CVP Media Servers automatically? Here we could find a description that tells this is possible. But it seems to me after several tests with couple of media servers that this feature is only available for agent greeting recorded files!
Thanks in advance
Correct Answer by vinodkewate about 3 years 5 months ago
The best solution is Microsoft SynchToy, we have been using using this in our environment and it is working fine.
You have to add source and destination pair for each media server other than the publisher one.
Overall Rating: 5 (1 ratings)
Edward Umansky Thu, 02/27/2014 - 10:07
  • Silver, 250 points or more
The built-in FTP step lets you copy to multiple destinations, so you can use it to copy to all servers from a CVP script. Otherwise you can setup a Windows Distributed File Share to automatically synch a folder across servers.
Correct Answer
vinodkewate Thu, 02/27/2014 - 11:40
Related Content
