ASA-2-106016 on same interface, but two subnets
Feb 19th, 2014
I get a strange problem here. We got another subnet from our ISP because we needed another block of IPs. Everything works fine, except one thing:
  Deny IP spoof from (XXX.XXX.XXX.XXX) to XXX.XXX.XXX.XXX on interface outside
The source IP is our main IP from our primary subnet and the destination is one of the IP in the new subnet. Do I need to add a special rule to allow this trafic??
Cisco ASA 5510
ASA Version 9.1(1)
Richard Burts Wed, 02/19/2014 - 13:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Could you tell us how you are using the second subnet that the ISP provided? And it might help if you would post from the config at least the parts that deal with both of the subnets? It is difficult to know if you need to add something until we know what you already have.
Rick
druideinformatique Thu, 02/20/2014 - 06:25
Hi Richard,
XXX.XXX.XXX is the primary subnet, YYY.YYY.YYY is the secondary.
Interface Ethernet0/1 "outside", is up, line protocol is up
  Hardware is i82546GB rev03, BW 100 Mbps, DLY 100 usec
Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
Input flow control is unsupported, output flow control is off
IP address XXX.XXX.XXX.42, subnet mask 255.255.255.248
interface Ethernet0/1
nameif outside
security-level 0
ip address XXX.XXX.XXX.42 255.255.255.248
related config:
object network bloc-externe-supp
subnet YYY.YYY.YYY.32 255.255.255.248
object network YYY.YYY.YYY.34
host YYY.YYY.YYY.34
route outside 0.0.0.0 0.0.0.0 XXX.XXX.XXX.41 1
route outside YYY.YYY.YYY.32 255.255.255.248 YYY.YYY.YYY.33 1
INGENIERIA Y CO... Wed, 02/19/2014 - 13:47
that's almost normal behavior on ASA if you don't enable the Proxy ARP on that interface and enabled anti-spoofing.
try with this.
ip verify reverse-path interface [interface_name (inside/outside/dmz)]
and this one
 arp permit-nonconnected
and this other one.
 no sysopt noproxyarp [interface_name (inside/outside/dmz)]
let us know if fix your problem !!!
had a great day!
druideinformatique Thu, 02/20/2014 - 06:28
I do have "arp permit-nonconnected", but not the other two. I will try it early next week.
