02-20-2014 10:26 AM - edited 07-05-2021 12:14 AM
I have an existing roaming 2.4 wireless network which consists of 4 autonomous 1242 APs. I need to expand the coverage area.
Can I add a controller and LAPs with the same SSID and expect my clients to roam from the autonomous AP to the LAP?
Or do I need to replace the 4 1242s with LAPs?
Solved! Go to Solution.
02-20-2014 10:35 AM
The code you would need is here:
c1240-rcvk9w8-tar.124-25e.JAO3.tar
http://software.cisco.com/download/release.html?mdfid=280237322&flowid=7588&softwareid=280775090&release=12.4.25e-JAO3&relind=AVAILABLE&rellifecycle=ED&reltype=latest
To convert the AP's, here are a few links to guide you:
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
https://supportforums.cisco.com/docs/DOC-18268
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
02-20-2014 10:32 AM
You do not want to mix them. If you get a WLC, then you can convert the autonomous AP's to lightweight.
02-20-2014 10:35 AM
02-20-2014 10:37 AM
Can autonomous 1242AG APs be converted to work with Cisco 2500 WLC?
Thanks!
02-20-2014 10:39 AM
Yes... I just posted some links on the instructions to convert them on my previous post.
