Warning message
UCCX 9 licences
Feb 20th, 2014
I'm trying to monitor licence use.  UCCX 9 has a great report in CUIC showing the maximum licences used in each hour.  Comparing the results of this against reports of the currently logged in users shows more licences in use than you would expect.  This leads me to believe agents are using a licence if they are leaving CAD running and connected to the system, even if they have clicked on the logout button.  Is that correct?
Can we see a list of the agents using licences?
Mark Potter
Jonathan Schulenberg Thu, 02/20/2014 - 20:18
  • Cisco Designated VIP,
    2017 IP Telephony
You can see usage through the CLI using the show uccx cad license usage command. I don't have a system nearby to test the logout behavior for you though. Please report back if you're able to confirm that; it would be an interesting behavior and possibly even a DoS vulnerability.
Please remember to rate helpful responses and identify helpful or correct answers.
Related Content
