Warning message
Rakesh K Thu, 02/20/2014 - 23:03
Hi Ravil
1) can you check by connecting laptop to the same port for which u have connected IP Phone.
          if laptop gets Ip address then problem with the phone.
2)Try to connect different IP phone which is in use.
Ravil Nagmetov Wed, 02/26/2014 - 01:27
All is well!
Restarted the central switch where was DHCP. After that, no problem. What was the reason and did not understand.
Thank you!
