Warning message
arp table entries from non existing layer3 vlan interface
Feb 21st, 2014
hello community
i have a strange behavior in my switch environment..
i have a 3750x switch stack which is the core switch in my network
there are some 2960s client switches with port-channel connected to that core switch
the core switch have different vlan interfaces. vlan1 for workstations and servers, vlan506 for management.
the client switches only have an management vlan interface (id506) - the native vlan1 is shutdown.
as i say, servers and workstations are located in vlan1. when i connect from a workstation, which have an ip address from vlan1, to the client switch and take an configuration backup using tftp on that workstation, the client switch insert an arp entry for this workstation - located in vlan1 - where the client switch dosent have an ip address..
when i troubleshoot this problem, i first see the mac address from the core switch vlan 506 interface and the ip address from the client in the arp table.
after few minutes the switch change the mac address to the real mac of the client..
this is strange because of arp.. the switch should not have arp entries from a layer3 interface in which he dosent have an ip adress.. am i right??
thank you in advance for your help, best regards and stay happy!
michael
Jon Marshall Fri, 02/21/2014 - 07:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Michael
Does the client switch have a default gateway configured ie. an IP in vlan 506 pointing to the VLAN 506 IP on the 3750 ?
If not can you post the output of "sh ip int vlan 506" from the 3750 ?
Jon
Michael KARL Fri, 02/21/2014 - 08:59
hi Jon
Yes he have!
config client switch:
interface Vlan506
ip address 172.25.6.8 255.255.255.0
ip default-gateway 172.25.6.254
config core switch:
interface Vlan506
ip address 172.25.6.1 255.255.255.0
standby 1 ip 172.25.6.254
standby 1 priority 115
standby 1 preempt
standby 1 authentication md5 key-string 7 xxxxxxxxxxx
i have also tried to deactivate proxy-arp on the core switch - but no affects..
regards - michael
Jon Marshall Fri, 02/21/2014 - 10:22
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Michael
I can see we were thinking along the same lines ie. proxy arp
I'm not sure what is happening then. Your understanding is correct ie. a switch with only one SVI should only have arp entries for other devices within that vlan including it's default gateway. It should not have any arp entries for devices from remote subnets as it would simply use it's default gateway to get to them.
Jon
Jon Marshall Fri, 02/21/2014 - 10:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Michael
Just one quick check.
Is the native vlan the same on both sides of the trunk link. If not STP should kick in but you never know.
Jon
Michael KARL Fri, 02/21/2014 - 10:58
yes Jon, it is. but one particularity, i have not vlan1 set as native vlan in case of vlan hopping prevention.
i have added a dummy vlan 1001 and use this as native vlan, so all other vlans are tagged..
i am not sure if i understand how STP should cause this problems..
Jon Marshall Fri, 02/21/2014 - 11:02
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Sorry what i meant was if you had accidentally configured the 2960 end of the trunk link to have a native vlan of 506 but the 3750 end to have a native vlan of 1 this could account for the arp getting through to the client.
You still shouldn't have seen what you did but i just wanted to rule out any issues.
The bit about STP was simply to say if the native vlan doesn't match it should actually block that vlan on the link that's all.
I wasn't suggesting the issue you are seeing was down to STP.
Jon
Michael KARL Fri, 02/21/2014 - 11:09
ok, i understand.
the native vlan configuration is on both sites the same.
the STP dont block a vlan as i see in the database
paul driver Fri, 02/21/2014 - 12:24
  • Green, 3000 points or more
Hello
possible ip.icmp.redirects?
try turning this off and test?
res
paul
Sent from Cisco Technical Support Android App
Michael KARL Fri, 02/21/2014 - 12:29
hi Paul
i would like to try this but i dont know how to do.
can you tell me the commands?
regards - michael
paul driver Fri, 02/21/2014 - 12:39
Hello
int xxx (svi)
no ip redirects
res
paul
Michael KARL Fri, 02/21/2014 - 12:42
thank you Paul, i try this on monday!
do i have interrupts after adding this command?
Jon Marshall Fri, 02/21/2014 - 12:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Paul
I understand what you are saying about redirects but for that to work wouldn't the 2960 also need a L3 SVI in vlan 1 up/up as well. It only has an SVI in vlan 506 so even if it did get redirected it couldn't send it direct because it doesn't have an interface in that vlan,
It may be i am mssing something so not saying you are wrong.
Jon
paul driver Fri, 02/21/2014 - 12:59
Hello
cannot see how.you would on the information you provided.
res
paul
Michael KARL Fri, 02/21/2014 - 13:12
ok, for better understanding, i post a snippet of the configuration (core and client switch)
core switch
version 15.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname coreswitch
boot-start-marker
boot-end-marker
logging buffered 30000
no logging console
aaa new-model
aaa authentication login default local
aaa authentication enable default none
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa accounting dot1x default start-stop group radius
aaa session-id common
clock timezone MET 1 0
clock summer-time MET-DST recurring last Sun Mar 2:00 last Sun Oct 2:00
switch 1 provision ws-c3750x-48
switch 2 provision ws-c3750x-48
switch 3 provision ws-c3750x-48
switch 4 provision ws-c3750x-48
switch 5 provision ws-c3750x-48
system mtu routing 1500
ip routing
ip dhcp snooping vlan 1,504
no ip dhcp snooping information option
ip domain-name domain.net
ip device tracking
dot1x system-auth-control
spanning-tree mode rapid-pvst
spanning-tree vlan 1-1000 priority 24576
errdisable recovery cause dhcp-rate-limit
vlan internal allocation policy ascending
interface Loopback0
description RID
ip address 192.168.254.102 255.255.255.255
interface Port-channel1
switchport trunk native vlan 1001
switchport mode trunk
ip dhcp snooping trust
interface GigabitEthernet1/1/1
channel-group 1 mode active
interface GigabitEthernet2/1/1
interface Vlan1
ip address 172.26.253.60 255.255.0.0 secondary
ip address 172.26.253.56 255.255.0.0
standby 1 ip 172.26.254.254
standby 1 preempt
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 7 xxxxx
ip ospf 1 area 11
interface Vlan506
standby 1 preempt
ip forward-protocol nd
no ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.25.254.243
ip route 172.25.10.0 255.255.254.0 172.26.255.242
ip route 172.25.12.0 255.255.254.0 172.26.255.242
client switch
version 15.2
no service pad
hostname client-switch
boot-start-marker
boot-end-marker
aaa new-model
switch 1 provision ws-c2960s-48ts-l
switch 2 provision ws-c2960s-48ts-l
switch 3 provision ws-c2960s-24ts-l
ip dhcp snooping
ip device tracking
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet1/0/49
interface GigabitEthernet2/0/49
interface Vlan1
no ip address
interface Vlan506
no ip http server
Michael KARL Wed, 03/05/2014 - 04:36
hello together
today i tried the "no ip redirect" (on core and edge switch), but no affect.
once i made a backup, the client switch add the ip in his arp table..
could it be in interaction with dot1x?
regards - michael
Richard Burts Wed, 03/05/2014 - 05:28
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Michael
I can not absolutely rule out the possibility that dot1x is causing this, but I doubt that it is.
Can you tell us the IP of the workstation and perhaps post the output of the arp table which has the workstation address in it? This might give us some clue about what is happening. Also can you post the output from the client switch of the command show ip interface vlan 506?
Am I correct in understanding that you are taking a backup of the client switch? That you have connected to the client switch and issue the command copy run tftp where the tftp server is the workstation connected to the client switch on vlan 1? This would mean that the management interface of the client switch is looking for the address of the workstation. I have seen situations where some Catalyst switches will arp for remote destinations. I wonder if that is the case here?
If on the client switch you run debug for arp we can perhaps tell whether the switch tries first to the core and then to the workstation or whether it just immediately sends the local arp. And if on the client switch you run debug for ip icmp then perhaps we can tell whether ip redirects are playing a role in this.
Rick
Michael KARL Wed, 03/05/2014 - 06:05
hi Rick
i agree about dot1x..
you understand my problem correctly, thats happend...
additional, i have installed prtg on the workstation where i have the tftp server installed..
on the client switches i have configured a krone job, which create the backup every day.. after done this job, the switch is unreachable from this workstation - as i am alerted from prtg..
maybe its a case like this here...
when i run debug arp i can see that the switch first tries the core switch - because of this i think the client switch adds the mac address of the layer3 interface of the core switch in his arp table..
is the debug ip icmp hi cpu performancy?
its an productive environment..
regards - michael
following the outputs (i have made some censored in mac address..):
first i clear the arp table in client switch - now it looks so:
MSW10K-01#clear arp 172.26.1.169
MSW10K-01#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  172.25.6.21           49   000b.xxxx.8fff  ARPA   Vlan506
Internet  172.25.6.75           30   5017.xxxx.e841  ARPA   Vlan506
Internet  172.25.6.90            -   4c00.xxxx.3841  ARPA   Vlan506
Internet  172.25.6.95          137   5017.xxxx.cf41  ARPA   Vlan506
Internet  172.25.6.96           27   7c95.xxxx.bbc1  ARPA   Vlan506
Internet  172.25.6.97          224   5017.xxxx.d9c1  ARPA   Vlan506
Internet  172.25.6.253          50   0008.xxxx.fc04  ARPA   Vlan506
Internet  172.25.6.254          90   0000.xxxx.ac02  ARPA   Vlan506
then i create a backup from the client switch, and then i get an arp entry from the workstation (172.26.1.169 with mac address 000b.xxxx.8fff from the layer3 interface of the core switch) where the tftp server is installed - but i dont have a layer3 interface in this subnet..
MSW10K-01#copy run tftp
Address or name of remote host []? 172.26.1.169
Destination filename [msw10k-01-confg]? MSW10K-01.cfg
21793 bytes copied in 10.712 secs (2034 bytes/sec)
MSW10K-01#sh arp
Internet  172.26.1.169            0   0000.xxxx.ac02  ARPA   Vlan506
MSW10K-01#
and the next strange thing is that after few minutes the arp entry "172.26.1.169 0000.xxxx.ac02 Vlan506" change to "172.26.1.169 0050.xxxx.7193 Vlan1" - the real mac address from the workstation where the tftp server is installed..
MSW10K-01#sh arp
Internet  172.26.1.169            0   0050.xxxx.7193  ARPA   Vlan1
MSW10K-01#sh ip int vl 506
Vlan506 is up, line protocol is up
  Internet address is 172.25.6.8/24
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Multicast reserved groups joined: 224.0.0.251
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP Flow switching is disabled
  IP CEF switching is disabled
  IP Null turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Probe proxy name replies are disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  Input features: MCI Check
  Output features: Check hwidb
Richard Burts Wed, 03/05/2014 - 07:20
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Michael
Thank you for the additional information. I find it especially interesting and informative that at first there is an ARP entry that shows the IP address of the workstation is associated with VLAN 506 and is the MAC used for HSRP. So this indicates that initially the client switch is doing what we expect and is sending its traffic for the workstation using the core switch as the next hop. But then it changes and the client switch associates the IP of the workstation with VLAN 1 and uses the MAC of the workstation. To me that suggests that ip redirect is probably the explanation.
I would think that debug ip icmp would not be so very intensive. If you are concerned about that you might consider using debug ip packet with an access list. You could configure an extended access list that permits just icmp redirects, perhaps access-list 199. And then you can use the command debug ip packet 199. The result is that debug for ip packet only reports when it sees redirect traffic. That should be somewhat less impact than just debug ip icmp (though I am not convinced that the difference would be significant).
Rick
paul driver Wed, 03/05/2014 - 10:17
Hello
Just to confirm
Your tftp server doesn't reside in either vlan 1 - 506 or is this a typo?
Res
Paul
Michael KARL Wed, 03/05/2014 - 11:46
hi Paul
the tftp server is located in vlan1
and i have tried to add the "no ip redirect" - but no matter..
best regards - michael
paul driver Wed, 03/05/2014 - 12:14
Hello
Forgive me for some reason I was looking at the svi for vlan 1 and seeing 24 bit ranges - think I need stronger glasses!
Where did you apply the no Icmp redirect command?
Res
Paul
Michael KARL Wed, 03/05/2014 - 22:54
hi Paul
no worries :-)
i applied it on the core switch in if vlan1 and if vlan506 and as well on the client switch in if vlan1 (which is shutdown) and if vlan506
Richard Burts Thu, 03/06/2014 - 06:46
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Would you post the output of show ip interface for both vlan 1 and vlan 506 on the core (and maybe on the client as well)?
Rick
Michael KARL Thu, 03/06/2014 - 07:14
sure, here are the outpus:
core:
MSWVSS-01#sh ip inter vl 1
Vlan1 is up, line protocol is up
  Internet address is 172.26.253.60/16
  MTU is 1500 bytes
  ICMP redirects are never sent
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP route-cache flags are Fast, CEF
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
MSWVSS-01#sh ip inter vl506
  Internet address is 172.25.6.1/24
  MTU is 1500 bytes
client:
MSW03K-01#sh ip int vl1
Vlan1 is administratively down, line protocol is down
  Internet protocol processing disabled
MSW03K-01#
MSW03K-01#sh ip int vl506
  MTU is 1500 bytes
Richard Burts Thu, 03/06/2014 - 09:31
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Michael
Thank you for the additional information. It does confirm that on the core switch both vlan 1 and vlan 506 have disabled both proxy arp and icmp redirects. It also shows that on the client switch that proxy arp is enabled on vlan 506. Would you disable proxy arp on that vlan interface and see what happens.
Rick
Michael KARL Thu, 03/06/2014 - 10:42
hi Rick
Same Problem.. :-(
Michael
  MTU is 1500 bytes
  IP fast switching is disabled
  IP multicast fast switching is disabled
  IP route-cache flags are No CEF, No Distributed
Richard Burts Thu, 03/06/2014 - 11:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Michael
Thanks. Clearly proxy arp is now disabled. Could you post the output of ipconfig /all from the workstation?
Rick
Michael KARL Thu, 03/06/2014 - 22:32
hi Rick
Surly, here it is:
Physical Address. . . . . . . . . : 00-50-xxxx-71-93
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 172.26.1.169(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 172.26.254.254
DNS Servers . . . . . . . . . . . : 172.26.1.20
                                    172.26.1.25
NetBIOS over Tcpip. . . . . . . . : Enabled
acampbell Fri, 03/07/2014 - 17:27
Micheal,
I ran in to some wird issues like this last year.
Can you try something for us.
On the client 2960 can you change the type of default gateway.
no ip default-gateway 172.25.6.254
ip route 0.0.0.0 0.0.0.0 172.25.6.254
Its worth a try
Michael KARL Sun, 03/09/2014 - 23:48
hi Acampbell
thank you for the tip.
i dont have activate the sdm lanbase-routing template on the client switches.
its still possible to work with default gateway.
Richard Burts Sun, 03/30/2014 - 14:38
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I wonder if you have made any progress on this issue?
Rick
Michael KARL Mon, 03/31/2014 - 00:38
hi Rick
Sorry..
i have opened an tac case and they are able to reprocedure the issue..
as i have a solution, i update the threat!
Richard Burts Mon, 03/31/2014 - 06:52
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Michael
Thanks for the update. I have been thinking about this and wondering if there is a difference between how router IOS treats ARP and how the switch Catalyst IOS treats ARP. With router IOS (and I believe in general how we expect devices to treat ARP) if the router receives an ARP request in which the source address is not in the subnet of the interface which received it then the router will reject the ARP request and not process it. I wonder if the switch IOS is operating differently. When you begin the backup the switch is communicating through the core switch. And I wonder if at some point the workstation sends an ARP response with its IP and MAC and whether the switch does process that ARP response and add it to its ARP table, even though its IP is not in the subnet of the management interface?
Rick
