Warning message
Communications Manager Reporting Report Description
Feb 21st, 2014
Hello Community, I use the Report Web Tool from CUCM 8.x (not CAR/CDR) and search for a description what the some Report Fields output means.
For Example:
Field:                                       Count:
Media Termination Point                2
etc etc......This is only a example.
I can´t really find a "offline" documentation. Only the CDR Docu, but this not help in this case.
Have the the community
I am happy for any help.
Regards Armin
HTH, please rate all useful posts and right answers.
yahsiel2004 Fri, 02/21/2014 - 08:17
  • Gold, 750 points or more
I'm not sure I follow here. Can you give us a better example?
Yosh
armin.wagenfueh... Fri, 02/21/2014 - 09:46
Hi, sorry, yes sure. When you go in CUCM Webpage "Reports". For example you generate a Report for Enterprise Parameters. I search for a description of the output "tables".
For example the output is
Table                                    Count:
Means that-- > 2 MTP are set overall configure Gateways and Trunks or 2 MPT only set in Trunks, or what means that?
Device -- > Count is 1660, means that are 1660 devices are configure or registered?
This is a easy example, but I search for a description for all the tables in the Report output.
Please see attachment
