Cisco Prime 9.5 - Failed to generated assurance backup
wilsonsant
Level 6
Level 6
I am try run the backup about the Cisco Prime and it is presenting failed. Any have idea about this?
Wilson
Hi Wilson,
Seems to be a bug.Do you get some logs here .
I was just checking few bugs but does not exactly match your issue.
Backup schedule - date handling issues
CSCuj11139
Symptom:
There are issues with handling dates in Backup schedule for Prime Assurance. Symptoms can include:
- Scheduling the the backup a few years ahead instead of the configured time.
- Not saving entries when date modifications have been done.
Conditions:
Issues may occur in Internet Explorer 9/8 and some versions of Firefox (eg: 21)
Workaround:
Use other supported browser.
PCA Backup requires SSH access for SFTP causing failures
CSCum88682
Symptom:
When trying to generate a backup from Prime Collaboration Assurance and store it to a secure SFTP server which is blocking SSH, the backup job will fail
Conditions:
Attempt to use a secure SFTP server blocking SSH.
Workaround:
Fix is available in Service Pack 1
Just a guess, if you can changing the browser?
regds,
aman
18 Replies 18
Aman Soi
Hi Wilson,
Can u share the snapshot of error message which appears ?
HAve u followed the below steps  while taking backup:
a. Login CPA with admin through putty using port 26
b. Create a Repository where the backup would be stored. You can keep name as BACKUP
c. then, u need to enter url sftp://IP address of machine where sftp is running/
d. user test password hash test .Same credentials need to be configured in sftp software.
e. backup backupfilename[PRIME]  repository BACKUP application cpcm
the backup filename would be created  as PRIME-YEARMONTHDATE-TIME.tar.gpg
I have taken backup using freeftpd software.
regds,
aman
Hi Aman,
Thanks a lot for your contact and I am sorry by late in the answer. I am not network administrator and  I am verify with my co-worker if created this way. I stopped and started the provision session, but, It still in progress.
Wilson
Hi Aman,
I spoken my co-worker and He told me that the backup model used is Web not CLI. We used the restart service cpcm, but, didn´t worked.
Thank You,
Wilson
Hi Wilson,
I checked the  guide  but did not find any option of backup taking through GUI.
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/collaboration/9-0/administration/guide/PC9-0AdminGuide.pdf
can u please share screenshot where u get this option along with error message?
regds,
aman
bkp_assurance.png Hi Aman,
We deleted the connection and created again, but, the error message changed. Now the message stay "In Progress" and not change status
I am attaching the print
Thanks a lot,
Wilson
Hi Wilson,
I think GUI option got introduced in Prime Assurance 9.5
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/collaboration/9-5/administration/guide/Cisco_Prime_Collaboration_Administration_Guide_9_5/backupandrestore.html
from CLI can u check status
admin# show backup history.
You can also try taking backup from CLI
the above commands remain same and
admin# backup cmbackup repository BACKUP application cpcm
Hope this helps.
regds,
aman
Hi Aman,
The Customer is using the 9.5 version. Yesterday I and my co-worker verified  that the backup by CLI is worked, but, in nothing moment worked in GUI interface.
SPOCPCA/admin# show backup history
File is at /opt/tempbackups/Bkp-Assurance-Diario/backup/appcomponent/db/emms_db_
21_02_14_16_11_24.dmp.gz
BACKUP of cmuser was SUCCESSFUL
21_02_14_16_03_42.dmp.gz
21_02_14_16_01_37.dmp.gz
15_02_14_01_00_02.dmp.gz
06_02_14_01_00_01.dmp.gz
SPOCPCA/admin#
This is the problem, the Customer know verify the log´s by GUI.
Thanks a lot,
Wilson
Hi Wilson,
This means through CLI, backup is successful but fails through GUI.
regds,
aman
Hi Aman,
This is the problem. The Customer would like use only GUI not CLI
Wilson
Hi Wilson,
CSCuj11139
Symptom:
Conditions:
Workaround:
CSCum88682
Symptom:
Conditions:
Workaround:
regds,
aman
Hi Aman,
I am doing the tests. The first test that I did was changed the browser. I tried to do the test with my Google Chrome 33.0.1750.117 and when I tried to do the test appear the message error:
There was an error while parsing and rendering the content. (Object #has no method 'getAttribute')
Error code WAP00008.
I am trying to do another test. I will inform to You by results.
Thanks a lot,
Wilson
Hi Aman,
The problem was solved. We changed the mode SFTP to FTP and the interface GUI worked.
Thanks a lot for Your help
Best Regards,
Wilson
Hi Wilson,
thanks for update.
How did ftp option clicked you? Did u open the TAC case?
regds,
aman
Hi Aman,
We didn´t open TAC case. The configuration was did in Web Page.
Administration > Backup Management > Backup Connection > FTP ou SFTP
De configuration about SFTP was deleted and created new with FTP
Wilson
