Cat 3850 reports "No such device" on usbflash0:
Feb 21st, 2014
I don't know why on my multiple 3850, command "sho usbflash0:" responds "no such device".
I did try with different USB sticks those verified work on PC .
The light on one of the USB sticks did light up and blinking.
Is there a way to "mount" this usbflsh0: ?
Thanks.
Leo Le
Leo Laohoo Fri, 02/21/2014 - 18:40
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
This means the 3rd party USB thumb drive is not supported.
NOT ALL 3rd party USB thumb drive is supported.  It doesn't matter if your PC can "see it" or not.  Try different sizes and/or different brand.   Why?
1.  The brand of the thumb drive does NOT mean that they were manufactured by the company.  Meaning, it may say Toshiba 16 Gb but it does NOT mean that Toshiba manufactured the thumb drive.  As a matter of fact, Toshiba 16 Gb and Toshiba 32 Gb does NOT guarantee that the thumb drive were manufactured by the same company.    Big companies, like Sandisk, Lexar, Toshiba, Verbatim, etc ... they BUY these product from different manufacturer.  The companies buy the thumb drive BARE.  That means no cover.  Just a tip and the PCB.  The company then design a "shape" or the end product.  This is why a Lexar 16 Gb could be manufactured by one company, and the 8 Gb can be manufactured by another company.  Now neither are these two companies do NOT follow standard or they do.  The main selling point is that these drives can be detected by Windows and Mac's and that's good enough for the big companies like Toshiba, Lexar, Sandisk, etc.
2.  You need to try different brands and different sizes.  The safest size to test is either 16 Gb or 32 Gb.  Don't try the bigger ones because there's no guarantee that they'll work.  The bigger ones are also more expensive, plus, WHY would you want to get, for example, a 64 Gb drive to put one or two different IOS in?
3.  Use the switch to format the USB flash drive FIRST before you load any IOS files into it.
nhuan022354 Mon, 02/24/2014 - 09:23
Hi Leo Laohoo, What is the SIZE and VENDOR of the USB stick that works for you ? Thanks Leo
Leo Laohoo Mon, 02/24/2014 - 13:24
  • Hall of Fame,
    2017 LAN, Wireless
Currently, I am using SanDisk Cruzer Facet 8 Gb.
This seem to work.
nhuan022354 Wed, 02/26/2014 - 08:10
Hi all,
I did not know that Cisco has their own USB flash drive . I search all other forum including routers,.... and found that there were quite a few users got problems when using Non-Cisco brand USB as well.
I will get Cisco USB flash drive just for sure .
Thanks Leol Laoho and Reza for your responses.
Leo Le
Reza Sharifi Fri, 02/21/2014 - 19:44
    2017 LAN
It maybe usb1.  What the output of dir flash or dir?
nhuan022354 Mon, 02/24/2014 - 09:21
Hi Reza,
I tested with only 1 switch and that is usbflash0:
What is your WORKING USB stick size and vendor?
Leo
