Warning message
cisco 887 adsl PCs cant access internet
Feb 22nd, 2014
Hello, this is my first message in this forum so, first of all, hello everyone, I´m Jose Manuel.
I bought recently a cisco 887 router and followed cisco´s tutorials to configure it but I cant access the internet from the PC, but I can ping and traceroute to any website from the "cisco configuration professional" program. I guess that the dialer interface is not connected properly to the LAN...
Let´s describe what I think I have got:
VLAN1.- 128.100.1.1 255.255.255.0 (NAT inside)  This is de Network i want my PC´s to be connected to.
Dialer0 and ATM0 (NAT outside) correctly configured, as the DNS works and I can Ping to googgle from "cisco configuration professional".
I think I followed instructions to send all incomming traffic from Dialer0-Atm0 to my my VLAN1 but It doesn´t work. (configuring the PCs LAN with default gateway 128.100.1.1).
I also followed the wizzard to configure NAT to get access to servers (WEB, ftp, ip cameras...) from outside.
Any help would be appreciated. I paste my current config.
Maybe I should erase all and start again??? How???
ip port-map user-protocol--8 port tcp 4906
ip port-map user-protocol--9 port tcp 4911
ip port-map user-protocol--2 port tcp 1111
ip port-map user-protocol--3 port tcp 1114
ip port-map user-protocol--1 port tcp 1110
ip port-map user-protocol--6 port tcp 4898
ip port-map user-protocol--7 port tcp 4899
ip port-map user-protocol--4 port tcp 1115
ip port-map user-protocol--5 port tcp 1117
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
parameter-map type regex ccp-regex-nonascii
pattern [^\x00-\x80]
parameter-map type protocol-info yahoo-servers
server name scs.msg.yahoo.com
server name scsa.msg.yahoo.com
server name scsb.msg.yahoo.com
server name scsc.msg.yahoo.com
server name scsd.msg.yahoo.com
server name cs16.msg.dcn.yahoo.com
server name cs19.msg.dcn.yahoo.com
server name cs42.msg.dcn.yahoo.com
server name cs53.msg.dcn.yahoo.com
server name cs54.msg.dcn.yahoo.com
server name ads1.vip.scd.yahoo.com
server name radio1.launch.vip.dal.yahoo.com
server name in1.msg.vip.re2.yahoo.com
server name data1.my.vip.sc5.yahoo.com
server name address1.pim.vip.mud.yahoo.com
server name edit.messenger.yahoo.com
server name messenger.yahoo.com
server name http.pager.yahoo.com
server name privacy.yahoo.com
server name csa.yahoo.com
server name csb.yahoo.com
server name csc.yahoo.com
parameter-map type protocol-info aol-servers
server name login.oscar.aol.com
server name toc.oscar.aol.com
server name oam-d09a.blue.aol.com
parameter-map type protocol-info msn-servers
server name messenger.hotmail.com
server name gateway.messenger.hotmail.com
server name webmessenger.msn.com
vpdn enable
vpdn-group pppoe
license udi pid CISCO887VA-K9 sn FCZ1749C5KJ
username cpais privilege 15 password 0 1234
controller VDSL 0
class-map type inspect match-any ccp-cls-protocol-p2p
match protocol edonkey signature
match protocol gnutella signature
match protocol kazaa2 signature
match protocol fasttrack signature
match protocol bittorrent signature
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect match-all SDM_GRE
match access-group name SDM_GRE
interface Ethernet0
description $ETH-LAN$
ip address 128.100.107.251 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 8/32
  pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface Vlan1
description $FW_INSIDE$
ip address 128.100.1.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface Dialer0
mtu 1492
ip address 81.43.106.62 255.255.255.224
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname [email protected]
ppp chap password 0 adslppp
ppp pap sent-username [email protected] password 0 adslppp
interface Dialer1
no ip address
ip nat inside
shutdown
interface Dialer2
no ip address
ip mtu 1452
shutdown
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat pool pool1 128.100.0.0 128.100.255.255 netmask 255.255.0.0
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static tcp 128.100.107.44 21 81.43.106.62 21 extendable
ip nat inside source static tcp 128.100.107.1 22 81.43.106.62 22 extendable
ip nat inside source static tcp 128.100.107.44 80 81.43.106.62 80 extendable
ip nat inside source static tcp 128.100.107.1 118 81.43.106.62 118 extendable
ip nat inside source static tcp 128.100.107.196 1110 81.43.106.62 1110 extendabl
e
ip nat inside source static tcp 128.100.107.193 1111 81.43.106.62 1111 extendabl
e
ip nat inside source static tcp 128.100.107.191 1114 81.43.106.62 1114 extendabl
e
ip nat inside source static tcp 128.100.107.192 1115 81.43.106.62 1115 extendabl
e
ip nat inside source static tcp 128.100.107.195 1117 81.43.106.62 1117 extendabl
e
ip nat inside source static tcp 128.100.107.44 4898 81.43.106.62 4898 extendable
ip nat inside source static tcp 128.100.107.229 4899 81.43.106.62 4899 extendabl
e
ip nat inside source static tcp 128.100.107.43 4906 81.43.106.62 4906 extendable
ip nat inside source static tcp 128.100.107.55 4911 81.43.106.62 4911 extendable
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended SDM_GRE
remark CCP_ACL Category=1
permit gre any any
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 128.100.107.0 0.0.0.255
access-list 1 permit 0.0.0.0 255.255.0.0
access-list 101 remark CCP_ACL Category=0
access-list 101 permit ip any host 128.100.107.44
dialer-list 1 protocol ip permit
snmp-server community yes RO
line con 0
exec-timeout 0 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
password 1234
login local
transport input telnet ssh
end
